Question about Porter Cable-Cable FN250C 1-inch to2-1/2-inch 16 Gauge Finish Nailer
The air is escaping from the end cap and it will not fire a nail
    President:
  • Porter Master
  • 1,388 Answers
You nailer is very easy to repair. Remove the head and replace the cylinder seal and other parts (including the cylinder spacer, white plastic ring around the cylinder) as needed. If the seal is not split, clean and lube all parts with silicone paste lube and retest. You can order parts from www.toolpartsdirect.com if you like to order off the web or contact your local Dewalt repair center.
Posted on Oct 18, 2011
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
My nail gun fires but no nail comes out
Wow these nailers have lots of problems. Try readjusting air pressure up or down. Look for a nail jammed in the end. Use good quality nails.
Mar 29, 2012 | RTO PasLode 900420 Impulse Framing Nailer
When i connect the air it sounds like all the air is escaping.
depends on where air is escaping from. If it is around the trigger then you need a new trigger valve (I have detailed instructions in the tip section on repair) If it is leaking thru the cap you have a pinch o ring or stuck firing valve. Let me know exactly where air is leaking and I will try to pinpoint the problem for you.
Mar 19, 2012 | Stanley Ring Kit for Bostitch N64C 1...
Hitachi NV50AP3 1-1/4-Inch to 2-Inch Cap Nailer Brand new gun, just bought it. Gun does not always cycle properly or cleanly cut the plastic caps off of the roll. Many times the cap just nailed is still...
Several of my customers are having the same problem here in New Mexico. If your air temperature is around 95 degrees or higher the plastic the caps are made of becomes too pliable to break off when the nail is fired through it. If you cool or freeze the cap roll, the caps will break off however this usually impractical. Get in the habit of moving the gun forward after firing a nail/cap to break the cap off. If you pull up or backwards you get a string of caps pulled out of the gun.
Sep 08, 2010 | Hitachi NV50AP3 Cap Nailer
The gun will fire staples, nails do not set.
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Air is escaping from the top of the bn125a brad nailer. It won't fire nails.
it sounds like you have a damaged o ring/seal that requires maintenance. You can go to Dewaltservicenet.com and download a breakdown for this tool and also order parts for it. When reinstalling new o rings don't forget to put a little bit of grease on them so they don't roll or pinch. Let me know if you need more help
Nov 13, 2009 | Porter Cable-Cable No.BN125A...
Porter Cable FN250B nailer won't nail. It makes a thunk when the trigger is pulled, and air escapes around the trigger. The piston does not move.It does not seem to be related to the saftey.
it sounds like there is a jammed nail in the nose/magazine or possibly a bent or broken driver. UNPLUG the air and remove the top cap carefully and see if the piston is twisted in the cylinder. Let me know and I will try and find you a breakdown for this tool
Nov 02, 2009 | Porter Cable Air Tools & Compressors
Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Sep 23, 2009 | Tools & Hardware - Others
Nailer only will fire one nail at a time and will not fire a second nail unless we take the nails out and put them back in. Nail also does not drive all the way in when it fires.
I found your post a couple times, when you remove the nails does the piston/driver slowly come down? Also do you hear any air leaking around the cap? When was the last time you had it serviced. It sounds like the o rings are dried out or worn flat and possibly a seal on top of the cylinder might be damaged. Not to worry though, it is rather inexpensive to repair all that yourself if you are handy with tools. Let me know and I will find a breakdown for you before you attempt anything
Jun 05, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Porter Cable-Cable FN250C 1-inch to2-1/2-inch 16 Gauge Finish Nailer Logo
209 people viewed this question
Top Porter Air Tools & Compressors Experts
John Trevino
john h
JOHN LAPIER
Are you a Porter Air Tool and Compressor Expert? Answer questions, earn points and help others
