Question about Ducane Grilling
No gas gets to the left side tube. - Ducane Grilling
    Brigadier General:
  • 4,736 Answers
Either the manifold valve for that particular burner has either failed or the burner orifice is clogged. The only way to check it, is to turn OFF and disconnect the gas and remove the the cooking grates, the flame tamer and the burner. Looking inside of the grill, where the burner was removed, you will see the burner orifice, which can be removed with appropriately sized open in wrench. Once it has been removed, look at the small hole in one end, carefully. If it appears to be clogged, either blow through the opposite end or use a straight pin the same size as the hole to clear out the obstruction. Whatever you do, don't make the hole larger! If it was clogged, you just solved the problem. If it wasn't clogged, check the venturi valve/tube on the open end of the burner you removed. It may also be clogged.Simply tapping it lightly with a screw driver handle, will often clear out an obstruction. If not, carefully probe the opening, until it's clear.
If none of the above solved the problem, the Manifold Valve will eed to be cleaned or replaced.
To do this, it will require the removal of all the plastic knobs on the the front of the control panel and then the removal of the control panel itself. By doing that, you should have complete access to the manifold and then can unscrew the couplings and remove it. Personally, if I were doing this, I'd replace the manifold valve, rather than trying to dismantle and clean it. Generally, you can purchase a new one from your grill's manufacturer.
Hope this helped you to troubleshoot and solve the problem.
Posted on Apr 06, 2011
Is there a reset switch on an LG dlex2501w dryer and where is it located?
no reset switch but some have a resettable thermostat on the gas burner tube. you can get at by taking off the plastic side vent cover on the right side shine a flashlight in there and you can see a thermostat with a button on it . its tight but can be done also you may see it better from the left side vent cover
Jan 01, 2017 | LG Dryers
My Fisher Paykel gas dryer gets way too hot on the right side. I can only use the lowest setting to dry my clothes. The side with the bearing gets so hot at any other setting, that you can not touch
Hello Anita;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I am not sure what components you have in your dryer.
So, these are possibilities:
1.) You may have a bad high temperature limit switch.
2.) Your gas regulator spool valve may be worn or stuck open. There is a setting screw on your gas regulator valve. Turn to the right to reduce gas flow and turn to the left to increase gas flow.
1/4 turn at a time.
3.) Your gas flame tube may have slipped forward or moved redirecting either the flame length or directing the flame at the bearing.
Nov 24, 2014 | Fisher Dryers
Woodboss 028av. I removes the air filter. on the left side there is a tiny plastic tube with a tiny spring inside it. what is this for
I think you are looking at the fuel tank breather pipe. The AV just means; anti vibration. My Stihl parts list shows it as 1117 350 5800 Tank vent.(Plastic Tube) And 1120 358 8105 Vent Insert. Its basically a small plastic tube with a restrictor in it that vents the tank. Only repair it if there is gas leaking. A local shop would help or go online.
Nov 03, 2014 | Garden
I HAVE A LG DLG2532W GAS DRYER. IT WILL NOT DRY. I HAVE TAKEN IT APART AND CAN SEE THE HEATING ELAMENT HEATING UP. CAN U HELP
Safety First, Unplug Dryer. There are two thermostats in the dryer. They are on the exhaust tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port. hope this helped Tim
May 22, 2011 | LG DLG2532 Gas Dryer
Hav 2009 yamaha 125 vino small gas line on left side keeps flowingas out wile its runing help.thanks
That tube is an overflow tube. It is leaking fuel because the cabs float valve is not shutting off the flow of fuel. The carb must be removed and inspected for debris as well as cleaned.
Apr 29, 2011 | Yamaha XV 125 - S Motorcycles
Keg-a-que flame cuts out when I close the lid
Must be some sort of air shutter on that puppy to alow for proper air to gas mix. Knock a few holes in that puppy. Where it the stack? I don't see it in the pic.
Jun 06, 2009 | Keg Products Keg-A-Que Grill
Cant get the burners to stay lite.
Spiders like to create little hidey webs in the tubes of propane grills and stoves.
Take it apart as much as you can and blow compressed air through all of the holes and apertures. You can either take it to the gas station and us the $.25 air machine or buy a can of compressed air at your computer store.
Apr 13, 2008 | Grilling
Grilling Logo
194 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
