Question about Garmin Forerunner 405 Handheld GPS Receiver
Display show ANT Test Mode...will not respond to anything
Just finished a run and hit stop on my training session. Went to reset the training session and that is when my watch went all wonky. The display currently shows:
ANT Test Mode
2457
Carrier
ANT Test On
I have tried to reset it but have had no luck. Please help.
  • Anonymous Sep 19, 2008
    Same Problem also Whats going on This has happened twice before a run I unlock the benzel and get the Freak screen -100 screen settings,squares and xxxxs The only way I have been able to reset is to connect the charger and it starts working again the next day
    ........Whats Up???
  • Anonymous Dec 05, 2008
    I have the same problem
    did you resolve it?
    thanks
    Eugenio
I did not solve the problem....it sort of just solved itself which is still extremely aggravating. Don't get me wrong, I am happy it is now working for the most part but to spend this kind of money and have it not work all the time is frustrating. This is not the first time I have encountered issues but I am generally able to reset it on my own. This last issue was just so bizzare that I cannot even begin to tell you all of the things the just popped up on the screen without me even touching it. At one point, it showed ANT Test Off, then it showed a huge X across the screen. Another time it simply read -1.00. After it was done displaying these random bits of data, I tried to reset one last time and had success. However, the data is not uploading to Garmin/connect. So my frustration continues.
Posted on Aug 06, 2008
SOURCE:
Microsoft word 2003 not responding
Is Word not responding or is the printer not responding?
If you have the installation disk just reinstall microsoft word.
Try booting up in Safe Mode and see if word works.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Apr 26, 2012 | Computers & Internet
Canon MX328 error display 5b00
Good Day Atzkie!
The error 5B00 in Canon MX328 is a waste ink tank full. The printer detected the number of times that the cartridge has been refilled and counted the volume of the waste ink that flows out from the cartridge to the absorber pads.
You can clear the error on the printer using a MP reset tool. This tool will reset the counter for the waste ink tank.
First of all you will need to download this MP328 tool and run it on your system.
To download, go to http://www.ziddu.com/download/15321203/MP328.exe.html.
Click the download button, then, enter the verification code before hitting another download button.
Click the save button to start downloading.
This is the procedure:
Connect first your printer directly to your computer via usb cable.
1. Make sure the printer is recognized by your computer.
2. Make sure that printer is set as default printer.
Set your printer in to Service Mode
1. Turn off the printer.
2. Press and hold down STOP/RESET button (red circle with inverted triangle)
3. While holding down STOP/RESET button, press and hold down ON button (power on button)
4. Release the STOP/RESET button while holding still the ON button.
5. While holding down ON button, press twice the STOP/RESET button
6. Release the ON button.
(On LCD control panel it will display Service Mode. Wait for a few seconds to display "IDLE" - that is the time when printer is set to Service Mode)
After setting the printer into service mode, run the MP328 tool.
Run MP328 Tool
1. From your download folder. Double click the MP328.exe to display the Service Tool window.
2. Once Service Tool window appear, press the MAIN button.
(It will take sometime to finish the transaction. You will see that the "IDLE" message disappear during the process. You will hear sounds from a series of movement inside the printer. Once finished, it will display "A function was finished") Click the button
3. Press the EEPROM Clear button
(It will take only a few seconds to finished the process)
3. Lastly, press the EEPROM button
After the procedure has finished, close the service tool window and restart your printer.
On your printer, it will ask you to set the language and country for final setup.
That's it Atzkie, that will fix your 5B00 problem.
If my solution was helpful, please feel free to accept my solution by pressing the YES button.
May 22, 2011 | Canon MP830 All-In-One Printer
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
I cannot clear a 'to a location' screen
I too was frustrated with this one. I played with the watch until I found the solution... Hope this helps!
For some reason I needed to be in the training mode to do this.
From the Time/Date mode, do the following:
1.) Press the start/stop button (upper metal button) to get out of Time/Date mode
2.) Press the Training side of the bezzle. You will see a workout display.
3.) Touch the GPS side of the bezzle until "to location" shows up
4.) Press the lap/reset button (lower metal button) to display a menu (may have to do this a couple of times, eventually when you release the button the menu does show up)
5.) Slide downward through the menu options until you find GPS
6.) Click the start/stop button (upper metal button) to toggle the gps on or off
7.) Press the lap/reset button (lower metal button) to exit the menu (goes to the "to a location" screen)
8.) Press and hold the Training side of the bezzle to return to your training screen
Apr 02, 2009 | Garmin Forerunner 405 Handheld GPS...
Garmin Forerunner 50 Train Display Settings
I was having the same problem and came across your post - I figured out how to change the secondary display.  While in Train mode, with your foot pod activated, hold the View button.  The secondary display will change and say "CAD" or "PACE"...keep doing this until you get to the right display.  Hope this helps!
Jan 15, 2009 | Garmin Forerunner 50
Can't get my GPS to turn on with the Garmin 405
I too was frustrated because of this. I played with the watch until I found the solution. Hope this helps!
Nov 16, 2008 | Garmin Forerunner 405 Handheld GPS...
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
My Pro-96 Suddenly Doesn't Pick Up Transmissions
on scan mode press (man) for manual then pgm then trunk. screen should read not trunked press mode. if it does say that then press scan, and it should work. but if it doesn't say not trunked then press mode until it does say not trunked, then press scan. should work.
Nov 23, 2007 | Radio Shack Pro-96 Scanner
Garmin Forerunner 405 Handheld GPS Receiver Logo
384 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
