Question about Pioneer PRO-FHD1 50 in. Plasma Television
My pionner fdh1 it wont star the power - Pioneer PRO-FHD1 50 in. Plasma Television
  • Pioneer Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 05, 2011
Vw sharan radio proble
HI Youssef
i believe that when you put the volume up to the max, you blow up the main fuse, because the new radio with volume up to the max consume more amps than the fuse is set to for the original radio.
now you have to look into the fuse boxes and replace the fuse, this will sort out the radio and the door lock problems as i hope.
Good luck
Aug 17, 2014 | Volkswagen Sharan Cars & Trucks
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
What proportions of rice to water?
usually one cup rice to one cup water. Or water should come up to your first joint when you carefully insert your index finger to top of rice
Dec 15, 2010 | Krups FDH1-12 8-Cup Rice Cooker
Pionner Bluetooth problem
Hi, does your Pioneer has USB port? If so then download the update to your PC then transfer to USB stick and connect to your radio. You wont be able transfer the update from your Nokia.
Aug 25, 2009 | Nokia N95 Cellular Phone
I have the pionner 1000 but the cue dont work wen
hi,
Micro switch of your cue button, need to be replaced.
djajay
djajay@inbox.com
Mar 07, 2009 | Pioneer CDJ-1000 CD Player
Star Power wont work
SOunds like something internal is fried and its no longer bueno.. just like the sixaxis controllers went out on me! open it up take a gander worse thing that can happen is you need to buy a new one on ebay for 20$
May 14, 2008 | Sony Playstation 3 (PS3) Console
i have the exact same problem and i cant find a fix for it
Dec 29, 2007 | Activision Guitar Hero II for Xbox 360...
I CANNOT USE MY DVD(dvd pionner 120s/2).
Are you trying to read or burn a dvd?
And please don't type in all caps.
Keep me posted.
Sep 06, 2006 | Pioneer DVD 120S (DVD-120S) Internal DVD...
Pioneer PRO-FHD1 50 in. Plasma Television Logo
243 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
