Clarion am/fm radio, stereo cassette and clock, just had new motor put in our car, now we need the security code so i can use radio. Its in my mitsubishi triton ute 2005. how do i get my four digit security code.
5 Suggested Answers
  • 53 Answers
SOURCE: Need code for stereo in 2005 Mitsubishi Triton Ute.
The only way to retrieve a code would be by calling clarion tech support, but they will ask for the purchase ticket to verify that you did buy it legit.
Posted on Jul 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
  • 11800 Answers
SOURCE: My Memorex MR 3400 digital
Yes, the belt has aged and when heated by the normal functioning, it extends and starts slipping - you just need to replace it.
Dismantle the deck and take the tape out. Measure it very carefully and order an identical replacement from here
http://www.studiosoundelectronics.com/cassette.htm#BELTS
Posted on Oct 18, 2010
kerguney
  • 577 Answers
SOURCE: Sony Amplifier, Sony CD Player,
The actual task of hooking up a home theater may take a little time, especially if you are doing a custom installation with lots of separate components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
Posted on Jun 22, 2011
Truck stalls when put in gear
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Nov 14, 2013 | OEM 1989 GMC V2500 Suburban Radio / CD...
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
SECURITY CODE NEEDED FOR CLARION CAR STEREO
www.radio-code.com/ -
www.radio-code.com/UnlockManu.htm -
floodle.net/extra/ebayinfo/car_radio_decode.html -
Those should sort you out.
Mar 25, 2010 | Clarion DB245 CD Player
Ay need codes
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Please note: Not all stereo codes can be calculated from the Serial Number
May 30, 2009 | Clarion ARX6670Z Cassette Player
CHANGED BATTERY IN 93 SAAB 900 NOW MY RADIO WON'T WORK
Someone put the wrong security code in the radio. Hold the DNR button down and the code will clear. Be sure you have the correct code to enter after clearing the current one.
Jan 24, 2009 | Clarion ABD340MP AM/FM CD/MP3/cassette...
Clarion car radion PT9561P for 1994 model Mazda 121
They still make cassettes ? JK
Power leads are pretty much standardized,
Check manual,website, buy the wiring adapter, or check with a installer.
This is a easy one : ) Sumthin
Jun 10, 2008 | Car Audio & Video
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
85 people viewed this question
 Grubhead
Grubhead
