Question about Lakewood HV9 Floor / Box Fan
The fan was running and then it just stop - Lakewood HV9 Floor / Box Fan
Hi, I have True T49F. When I plug in the system runs, but the evap fans was run. Then for a minute the Compressor frost up. So what do I need to check? Please help......
The compressor will appear to freeze up if the evaporator fan stops running while the compressor is running. I would look for a defective evaporator fan if I understand you correctly. Fans will sometimes stop when they should be running. Defective fan does not always stop running when they go bad
Appliance 911 Sea Breeze
Mar 14, 2017 | True Refrigerators
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Cooling fan runs continuously, even after shutting the ignition off
sounds like it could be a relay.
With everything plugged in and the fans running with the key off remove the cooling fan 1 fuse. Do they stop?
If they do not stop remove the cooling fan 2 fuse. Do they stop?
Aug 15, 2012 | 2002 Pontiac Montana
How do i test my fan blower in the refridgerator? calls for fan but fan trys and stops, the fan runs free and rocks back and fore wen stops.
If it has a burnt smell then it is probably no good. Thats the easiest way to find out. If it try to run then stop it is probably burnt or shorted out.
Jul 02, 2010 | Refrigerators
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
PSU problem. Power on, fans spin then stop. 15 secs pass fans try to spin then stop and so-on ?
Hope your system is running and only the fan is not running. in that case fan needs replacement. only the fan can be replaced. good luck
Dec 18, 2008 | Computers & Internet
Lakewood HV9 Floor / Box Fan Logo
54 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
