Question about Mirage OMNI S8 Speaker
My subwoofer just stopped working, it has power going to it but no sound. On the back of the sub it has the option to use a sub cable to the receiver as well as wiring it the old fashion way (red to red black to black). My receiver does not a have a sub woofer cable inlet so i must wire it using the speaker/sub wire. When i tried the sub on a friends receiver using a sub cable it worked, however it wont work using speaker cable. It is not the receiver either. My question is why the sub cable inlet just stopped working? What can i do?
joebert
  • 29 Answers
SOURCE: Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
Posted on May 15, 2007
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
SOURCE: cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
Posted on May 31, 2009
  • 49 Answers
SOURCE: Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Posted on Mar 04, 2010
Testimonial: "Spot-on Ron! I'll get another fuse. Many thanks, Chris"
Why does my MCS sub 10 not turn on?
Is that the right part number, MCS 10, and not MCS100?
The MCS systems use a basic sub which is matched to the satellites. There's very few controls other than level on the MCS100. So as long as the power light is illuminated the there's very little other than the volume control that could be set wrong on the sub. So what it comes down to is either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay
Switch off the sub and reconnect the phono/RCA to the sub out socket on the receiver. You now know it is connected correctly.
Go in to the receiver's menu and check the speaker settings. Is subwoofer present? Yes/No
Are the satellites all set to Small? (they should be with this system)
Are you playing a 5.1 source in DD or DTS to ensure that the sub gets a signal? Play a BD or DVD.
On the speaker balances, is the sub channel set to 0dB?
As long as all the above is set as listed, then the only things stopping the sub working would then be insufficient volume at the sub's Vol control (so increase it), or an intermittent cable connection (wiggle the cable), or a broken subwoofer out signal at the receiver.
Aug 06, 2014 | Boston Acoustics Audio Players & Recorders
I cant seem to get the sub woofer to put out sound
Hello, are you using the subwoofer output on the receiver?
Did you turn the subwoofer on within the receivers onscreen setup?
this requires going into the menu selecting speaker setup and telling the receiver that you do have a subwoofer connected.
if you have done all this I would try to fist make sure the sub is working. easiest way is to plug a source directly into the rca inputs of the sub and see if it powers up. A CD player or even an ipod with the right connector will work.
if the sub powers on and produces sound then the issue is in the receiver and you will have to play with the setup. Its possible that the output jack is bad, I've had that happen when I pulled on an RCA cable and pulled out the socket but that's rare.
Is the subwoofer set to turn on automaticly when a signal is sensed?
does it have a switch to select high or low level inputs (speaker jacks or RCA connections on the back)
hope that helps
remember start by making sure the sub works then figure out why the receiver isn't sending a signal.
Feb 19, 2010 | Yamaha RX-V661 Receiver
PS-212 Suddenly stopped working
I HAVE 4 PS212 AND FROM WHAT YOU ARE DISCRIBING SOUNDS SIMILIAR TO WHAT HAPPENED TO ME. PLAYING THE SUB AT FULL VOLUME AND CLIPPING OCCURED NOT KNOWING THAT THE FAINT SMELL WAS THE VOICE COIL BURNING AND CONTINUING TO PLAY UNTIL KNOW SOUND LESSON LEARNED BUY A BIGGER SUB SYSTEM OR REPLACE YOUR SUB WOOFER.
IN MY OPPINION THIS IS A VERY GOOD PRODUCT WHICH I HAVE BEEN ABUSEING FOR MONTHS . SO QUIT WHINEING AND PAY YOUR DUES.
May 30, 2009 | Infinity PS212 Subwoofer
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Will skw204 power sub work with my txsr605 onkyo
yes here is the manual for it.
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
now you will see this picture on page 5
768816d.jpg now where it says 6 this is your line input. Now you will plug in a subwoofer cable to this and on back of your receiver to the subwoofer output. and you now must enable the subwoofer option in the setup menu of receiver i think it would be under speaker configuration.
Mar 01, 2009 | Onkyo TX-SR605 Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
No Sound from Subwoofer
You should be able to check this yourself pretty easily, Just connect the power and turn it on. Connect an audio cable to the input. Make sure the level control on the sub is turned about halfway up or more. Now, touch your finger to the tip of the plug on the other end of the audio cable. You should get a nice hum out of the subwoofer. If not, then the sub is bad - if it has a user-replaceable fuse you might check that first. If you do get a hum out of it, then the sub is ok, and the problem is elsewhere. Might be a simple as a bad cable or an option on your amp/receiver is set wrong.
Feb 14, 2008 | Kenwood KSC-WA100 Car Subwoofer
Connecting subwoofer to receiver.
have u checked that the sub option on the reciver is on?
Jan 06, 2006 | Kenwood 107VR
Mirage OMNI S8 Speaker Logo
141 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
