Question about Conair Gs4 Iron
How do you open the steamer to put water in it?
Where don I put in the water on my DA-55 steamer
http://www.rowenta.co.uk/rowenta/frame.aspx
Feb 11, 2015 | Irons
I am unable to twist off the top of the iron in order to put water into the steamer. I have tried twisting it clockwise and counter-clockwise as instructed. I
Please let me know the make and model of the iron. We have a Delonghi Pro300 and I fashioned an opener out of a 2 inch pvc t that I purchased at Lowes. It allows my wife to open the steam reservoir with no problem.
Dec 03, 2014 | Top Irons
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Hi floyd, a friend of nime gave me a steamer and i dont know how to work it i dont know see where you put the water in at.i need to know step by step instrutions on how to work it.
what brand? what does it look like? should be a heavy screw-on cap on water tank. Fill with soft or distilled water, power on, and should be a red light that comes on when hot enough for steam
May 14, 2012 | Rowenta Commercial Garment Steamer - White
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Conair Gs4 Iron Logo
46 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
D. E. Hev
Are you a Conair Iron Expert? Answer questions, earn points and help others
