Question about Brother MFC255CW All-in-One InkJet Printer
My wireless printer will not print from my computer. I get an error message whenever I try to print.
  • 1,218 Answers
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
Posted on Apr 06, 2011
Error message
copy on my machine then i tray to copy
May 06, 2013 | Brother MFC-7340 All-In-One Laser Printer
Black snudges
A firmware update for your model addresses the print quality problem you are experiencing. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After successfully updating your printer, run the Deep Clean Printhead function on your printer. Press the Setup button > Maintenance > Deep Clean Printhead.
Try to print a document again to verify that the print quality has improved.
Should the problem continue, please contact Lexmark Technical Support Center for further assistance.
Jan 26, 2012 | Lexmark Prospect Pro205 Wireless...
Hi, Whenever I try to print, I get the following message: Paper Size Mismatch. The duplex unit is only compatible with US Letter and A4 paper sizes. What do I do? I haven't changed my paper or...
Make sure the correct paper size is set on your computer before printing. With your file open, click File > Print > Properties > under Print Setup tab in the Paper Options area, ensure the correct Paper Size and Paper Type is set. Click OK to save the setting. Try to print again.
Jul 27, 2011 | Lexmark Prospect Pro205 Wireless...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error msg and printer wont print without pushing "on" button, wireless connection
need to hook up printer to computer. The software I had I threw it away. The printer model number is 4126-005. The serial number is 02320543500 2006/08.
May 24, 2009 | HP Photosmart 3310 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error 0xc18a0106
Push OK, CANCEL, BLACK, & COLOR all at once while turning the printer off, turn it back on. I had to do this 2 times to get it to work and then it went through a long period of maintanence before I could print
Jun 23, 2008 | HP Photosmart 3210 Printer
Error msg status 1
sounds like a communication error, are you wireless?
try connecting direct.
Feb 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC255CW All-in-One InkJet Printer Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
