Question about Energizer Eveready TUF4D1E 4D Cell Lantern
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits and not screws Thank you for your help. If there were a diagram I cound probable figure it out, they say a picture is worth a thousand words (smile)
    Problem Solver:
  • 6 Answers
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Posted on Jul 27, 2012
  • ladyafl
    ladyafl Aug 22, 2012
    THANK YOU!!!!
2 Suggested Answers
  • 16 Answers
SOURCE: how to change the batteries on the TUF4D1
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
Posted on Feb 12, 2011
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
I need to change the battery on a Highgear LED Fuse Micro lantern model #10084HG
It's easy once you figure it out. Unscrew the top and then push down on the exposed screw threads with your thumb. The internal "guts" slide out the bottom.
Feb 12, 2014 | HighGear Fuse Micro Lantern, Red
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Jan 09, 2013 | Energizer Eveready Utility Lantern Uses 6V...
Polar express lantern stoped working how do i get the battery changed
It's possible but you have to use a razor saw and cut the top off the lantern. Go around the top and cut only through the plastic. Don't try to saw a single cut all the way through the whole top at once. You can then replace the 2 CR1220 batteries inside. I added some tabs to the top with scrap plastic and drilled holes so the handle would hold everything in place.
Dec 02, 2012 | Toys
I have a Vector VEC1378 rechargeable lantern - does this lantern also take a battery or must it be electrically charged only? If so, how do you open the battery case. Thank you.
I have the same and bought a $20 6v lead acid replacement from the Batteries Store. There are 4 small screws hidden under the foam rubber ring pad on the bottom. Very easy to open and swap out the battery. That said if you want to sell me your old lantern as is, I would enjoy having a second one for camping. Thanks and good luck. I can be reached at rudock1 at yahoo dot com. -Billy
Jul 25, 2011 | Vector Sport & Outdoor - Others
Why i cant buy lanterns in smurf village? Level 30
It took me forever to figure out, but the "lanterns" are two poles (striped red and white like a candy cane) with three little lights on them. Two are square, one is circular. They are $1500.00.
Apr 20, 2011 | iPhone Apps
How do I access batteries in energizer hardcase spotlight mod TUFRC1 (4XAA batteries) tanx
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out. Alternatively the rear of the case should twist off revealing the batteries as above.
Feb 07, 2011 | Garden
How to change the batteries on the TUF4D1
Feb 08, 2010 | Energizer Camping, Backpacking & Hiking
Trying to figure out how to change batteries in a energizer hardcase lantern tuf4d1.
the bottom section turns and the upper section with the handle is just a shell. these are very good lights
Nov 13, 2009 | Hand Tools
Energizer Eveready TUF4D1E 4D Cell Lantern Logo
392 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
weirdtop
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
