Question about Napoleon "Prestige I P450RBNSS" Gas Grill
I have low flow on the first manifold (far left) on my napoleon 600. Removed and cleaned the manifold, no joy. Removed and cleaned venturi manifold and jet, still no joy? Have new tank and regulator installed and have pressure to all other manifolds. What next? Swap burner valves to see if the problem follows the valve? Or just remove and try to clean it?
    Brigadier General:
  • 4,736 Answers
If you're going to remove it, to swap it with another valve, why not inspect and clean it while it's out? That way you want have to remove it twice. Keep in mind, you may end up having to replace it anyway.
Posted on Apr 05, 2011
I have a napoleon hd46 LP gas fire place ,The igniter works but the maine burner doesn't fire up can you help.
when you open gas , do you smell it? if not maybe venturi is blocked. can you light the burner with a lighter, if so gas is not problem. i think you have to do some troubleshooting first to eliminate the cause. if igniter works its a gas problem, if gas is coming in, its the igniter
Sep 29, 2017 | Napoleon Grilling
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
I put a new fuel pump on my 90 cbr 600, when I start it up it flows fuel out of a hose on the far left carb, and all over the motor, is it supplying too much fuel?
Sounds like a stuck float on the left carb. Try tapping the carb bowl while the gas is running through. carbs probably need cleaning.
Apr 01, 2014 | 1990 Honda CBR 600 F(1)L
1994 Honda VT 600 C Shadow bogging at high RPM
Hi, Anonymous engine "BOG" is mainly caused by a rich air and lean fuel condition but it can also be caused by a lean air and rich fuel condition this situation rarely occurs and is only caused by the misinformed weekend warrior that owns a toolbox.
The more you open your throttle the more vacuum you are creating in your carburetor venturi and your intake manifold. When you are operating at higher RPM any unmetered air that leaks into your system can become more obvious.
Unmetered air is air that is getting into your system after the fuel has been delivered. If you have unmetered air getting into your system between the butterfly/slide of the carburetor and the cylinder head this will create a lean condition.
All of the rubber components of the fuel system like vacuum hoses and intake manifold that you mount the carburetor to are made of rubber. If none of these components have been changed out they are more than likely highly degraded and probably cracked in places to allow unwanted-unmetered-contaminated air into the combustion chamber. Check all of your vacuum lines and vacuum plugs for carburetor synchronization. The vacuum plugs are in the head just after the rubber intake manifolds. The petcock has a vacuum line as well as part of the emission system.
1. Check the intake manifold for cracks.
2. Ensure the bands used to tighten the manifolds down on the intake are secure and have not bound up the manifold.
3. Make sure air box fittings are not warped and fit completely over the carburetor.
Your airbox is metering air and is the first step in a process of consuming air and fuel. The system requires the resistance of the air filter in order to get the proper vacuum to "SUCK" the fuel out of the float bowl and create the proper venturi effect.
Improper mounting and sealing of the airbox will create a small lean effect. This might seem like no big deal but you are inviting dust and debris in your engine that is doing slow damage by not having proper fitment. Fix it so you know it's not contributing to your issue. Pick the low hanging fruit first.
Do not go and start adjusting anything at this point. It ran fine before. There is something wrong with the assembly or a component. Do not adjust your floats. Get it back to where it was. The moment you start tweaking everything is the moment you lose OEM settings which are a must have for fine tuning and maximum performance.
Fine tuning your carburetor and multi carb syncing come at the very end following the proper procedure established by the Carburetor Gods.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bogging down at high speeds
Losing power bogging on Freeway High RPM Scary Help Please
Honda VT600C Shadow VLX Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT600C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 29, 2013 | 1994 Honda VT 600 C Shadow
Low flame on one side
If your grill is older and has seen several seasons check for obstructions elsewhere the venturi is only one place for problems, check for hose kinks loose connections. If this is in a cold weather area, it maybe just low pressure. Also look for collected/ponded water in the burner tubes, especially if the flames are yellow.
Jan 13, 2013 | Broilmaster Premium P4 Grill
I have very low water pressure on my 4 year old Whirlpool WHES40 Water softener when the service position. When bypassed the water in my home returns to normal. I have cleaned the venturi and nozzle and...
The pressure loss is due to either a plugged distributor/manifold or upper basket. The head must be removed for access to the manifold and upper basket. The manifold runs from the head to the bottom of the tank. This is where all the soft water is drawn from and is the most likely cause for pressure loss. Water must be shut off and tank depressurized before attempting to remove the head of softener to access these parts. Clean the slots in the manifold and upper basket. They are probably plugged with iron, resin and/or gravel and re-install.
RJ
Aug 22, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Country flame nps-1000 made in 1996 has a lazy flame, low heat output, and having a difficult time regulating auger feed any suggestions
not getting enough air -clean and vacuum unit and check fresh air flow damper is not opened enough need more air or flue clogged and needs cleaning
Feb 15, 2010 | Napoleon Auburn Pellet Stove Heater
Smoky smell from Napoleon pellet stove.
it over fueling at low setting this is a comon problem and will do exsaclly what you have said
Dec 30, 2009 | Napoleon Auburn Pellet Stove Heater
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
Napoleon "Prestige I P450RBNSS" Gas Grill Logo
115 people viewed this question
Top Napoleon Grilling Experts
Paul Carew
Lawrence Oravetz
Pierre Legault
Are you a Napoleon Grilling Expert? Answer questions, earn points and help others
