SOURCE: panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
SOURCE: removing microwave surround
Ahh, that's one of those British brands I can't get any information about.
If you have the installation instructions, they would tell you how to install it, and it's as simple as reversing the procedure.
BUT maybe it's not too different from US models in the sense that many of its components can be accessed without pulling it from the wall, assuming it's the over the range type.
I would first refer you here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
In most cases, you unplug the oven, then remove the vent grille across the top, then you'll see a screw holding the top of the control panel frame in place.
Once that screw is out, you probably lift up and either swing forward or twist to loosen the control panel.
You should be able to access the fuse, etc. at this point.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If it's built into a cabinet, then you would have to remove the metal frame covering the area in which the microwave rests.
Be safe.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: micriowave key panel
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide
with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
SOURCE: GE Spacemaker Microwave Handle Replacement
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: replacement part needed for GE Spacemaker Micro. (JVM1631BB004)
Appliance online store:
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
The magnetron in your microwave has probably gone out. The magnetron is the
part of the microwave oven that produces microwaves. If you unit is a built in model,
it will likely cost more to fix than a new one. Same thing goes for a
countertop unit.
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
