Imy tv kinda got smushed in my recent move. but inside there is 3 computer boards....the one in the center has a small crack thru it....where can i find it?
  • 5,568 Answers
If you always include make and model number, you will get more useful responses but you can try here:
Used TV parts
Posted on Apr 05, 2011
Hitachi Plasma Flat Screen T.V. Mod #42EDT41 Has 1" vertical line, 10 inch from left side, top to bottom. another vertical line 14 inches from 1st vertical line.could you please let me know what...
This buffer board normally will just bypass the video to the screen from the main digital board.
There could be other problems with the main digital control board but it could also have a problem with the flex cables that connect from 6871QRH037A to the plasma panel.
Aug 13, 2008 | Televison & Video
Screen looks like it is a barcode
Sounds like the tiny E2P board with the EPROMS may be bad or problem on digital boards with leaking caps.
E2P not easy to get at as buried in between two boards under the shield on one.
Apr 02, 2012 | Mitsubishi WD-57732 Projection Television
Imy 98 buick is overheating the water comes out from the pasenger side inside da car..right under the glove box
That is where your Heater core is located. Its like a little radiater that your vents blow thru to get hot air for heating your interior. If thats leaking, its not gunna stop. Take this car in right away before you run your coolent dry and trash your car.
Jan 10, 2011 | 1998 Buick Century
60" LG Lcd Projection TV
ok u could have somthing on the lcd srenn and thta is y u have a yellow spot what i would do first is pull out the unit and look at the luc screen and buld to see if u have somthing on it i could be a small pice of papaer or anything it is best if u look at it thru the lens on the inside on the tv when u have it on because u can see i t better i hope this hps marty
Oct 12, 2008 | Hitachi 60V500 60" Rear Projection...
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
No picture and a "whistle"
If your friend is being honest, and why shouldnt he, and the set was knocked over, I'll bet there is now a small crack in the main board. Cracks in boards due to dropping or "knocking over" usually occur next to the flyback transformer or tuner. Cracks in boards are very easy to fix so if you do not have experience working inside TV's then allow a qualified tech to handle it for you.
Sep 01, 2007 | Sony KV-27FS13 27" TV
Recently moved the tv
The possibilities are that either you have a bad connections somwhere causing a shutdown or a board has a crack in it that happened from moving it.
Feb 25, 2007 | RCA P61927 61" Rear Projection Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
