Question about Toshiba Satellite L555-S7916 Notebook
When my toshiba l555 battery runs low, I can plug in the charger but it will not charge unless I close it and put it in sleep mode. The battery icon in the lower right hand corner will read "plugged in, not charging" Is this common or fixable?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 89 Answers
This is a problem I recently went through also, on my Dell Inspirion 1420. What you should do is replace the battery of the laptop, that fixed it for me. Laptop batteries are easy to find and replace, and you almost never have to open up a laptop to replace the battery. Generally you can find the battery on the bottom of the laptop, near the part where the monitor meets the main body of the laptop. Unfortunately, laptop batteries aren't very cheap, usually $50-$100, but I quick searched a replacement battery and found one for $35 for the Toshiba L555 series here, pretty hard to beat, and from a trusted seller too.
Posted on Apr 05, 2011
My Acer Aspire 7750g-6857 will only charge when in sleep, hibernate, or shut off. When i plug the charger in, the power light will flash and it won't charge. Please help..
try to remove the battery, plugged into charger and see what does the icon shows. right click the icon and select power option try to restore all settings to default. if this would help.
thanks
Mar 31, 2014 | Acer Aspire Computers & Internet
Toshiba Satellite A105 hangs when charger is plugged
Toshiba Satellite laptops come with a unique power management software program that regulates the power consumption of your laptop. While this program is often helpful in extending laptop battery time, the program is also known to cause some operational difficulties when software conflicts occur. At some point you may want to change your power options, or remove the program.
Click "Start" and then "Control Panel." Locate the "Toshiba Power Manager" program among the Control Panel icons. Note that this differs from the familiar Windows "Power Options" icon. Open the Power Manager application. If you want to merely modify the current settings, the Power Manager gives you many options to choose from. For maximum battery life, consider setting the Power Manager to put the laptop into various states of "sleep" after so many minutes of inactivity. Select the menu items offered to achieve power savings for the monitor or hard drive, or both. Click "Save Settings" and exit the program. Remove the Power Manager if your laptop is prone to "freezing" or seems to have difficulty "waking up" from a Sleep or Hibernation mode. Go to "Start" and "Control Panel" and choose "Add Remove Programs." Navigate to the "Toshiba Power Saver" listing. Click "Remove." When Windows is done scrubbing the program from the system, click "OK" and exit Control Panel. Reboot. The Windows on-board power management program will now take precedence over this function.
Feb 14, 2013 | Toshiba Satellite A105 Notebook
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Troubleshooting with Toshiba Satellite A75-S211 Notebook
try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
Won't Turn On Unless Plugged In
What is the make/model of the laptop? It looks like the battery is not holding a charge. Have you tried to remove the battery and put the battery back in?
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite L555-S7916 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
