Question about Breville Die Cast 800ESXL Espresso Machine
My Breville 800 es stops working about 20 seconds into making a shot. The LED flashes indicating that it's heating and nothing works! I can't make any more shots or steam coffee. If I turn the machine off for about 30 secs, I can steam milk again (and then have 20 seconds to make a shot before it cuts out) I can always steam milk for as long as I like assuming it's the first thing I do! I have tried removing the water tank, turning the machine on and off etc etc etc. It seems the only thing that will allow me to make coffee again is to keep turning it off ... I'm assuming from reading other comments that it is the thermostat that is the problem ... where can I get it fixed ... I am on the southside of brisbane australia
SOURCE: breville 800esxl won't extract coffee or steam milk.
is your machine new or is this a new problem? If you have had the machine for a while there is a possibility that your double wall filter is clog between the walls which would prevent the water from going through (this happens when your grind is too fine). If however the water does not go through when you do not have a filter in the basket than you have a diferent problem.
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Posted on Mar 18, 2009
SOURCE: I neeed a seal for
Contact Sparkey's Small Appliances Phone 3262 7129
Posted on Mar 24, 2009
SOURCE: Breville 800 esxl
This is very normal - allow the hot water to exit the wand outside of the milk frother, then, as the water stops, position the wand into the milk jug and steam.
Posted on Dec 28, 2009
  • 668 Answers
SOURCE: My Breville 300es stops working
First of all, I would suggest unplugging the coffee maker and wait 10 minutes and then plug it back to reset the microprocessor.Then switch on the coffee maker, It should work fine.
If you are facing the problem then a thermostat inside the coffee maker has failed. It is not turning the element on to brew the coffee.You need to replace the thermostat.
Hope this helps.
For further queries feel free to ask us.
Shane
Posted on Mar 01, 2011
The bottom heating elements on my breville toaster oven model BOV 800 XL stopped working. What to do?
You could have them replaced but will it be cost effective to do so? Maybe a new toaster would be better and cheaper.
Sep 17, 2017 | Breville Toaster Ovens
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
Aeg electrolux dryer
Displaying the alarm code
The alarm code is displayed by a repeated sequence of flashing of the ANTI-CREASE/END OF CYCLE LED (0.4 seconds on, 0.4 seconds off, with a pause of 2.5 seconds between sequences). The buzzer emits a series of ,bips" in synchronization with the flashing of the LED.
  • ANTI-CREASE/END OF CYCLE LED: indicates the first number of the a alarm code
  • START/PAUSE LED: indicates the second number of the alarm code
Now you must count how many times the LED lit up and we will know the fault code.
24383347-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
May 10, 2014 | AEG Dryers
Doesn't heat the water Start...makes noise, the
the flashing heating light indicates that it isn't getting water. This could indicate that your pump has gone bad.
Oct 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
The coffee maker will not work. It keeps saying
As others have said...just keep reseating the water tank, 20-30 times may be necessary. You will see air bubble come up and until you stop seeing bubbles, keep dropping the tank into place. Eventually it will start to **** water from the tank filling the brewer with about 20oz of water. Wait a couple minutes for the water to heat and it will indicate ready and just select brew cup size. This will work. We just had the same problem today with our first breville coffee brewer and now it works great.
Jul 31, 2009 | Breville BKC600XL Coffee Maker
Dv2000 there was no desplay and after i heat the nvidia chip
Dear Sir: We are here to help you and make able to fix your computer, however, we will need certain information, so we may proceed helping you: (1) The manufacturer of the Computer and/or the Computer Trade Name; (2) The Model Name and Number; (3) The Motherboard Identification Number. If you have trouble finding it, we can help you! (4) A detailed "report" of what happened. Please tell us what has happened so far. The light flashing is an indication of a problem, but we need a little more, like what happened before. Did you have your laptop out for repairs and a day after it stopped working? We need every detail you can give us, starting from the first signs, especially if you had someone else work on it. You said that after a day the computer does work. How did it stop working? Did it ever work on the second day? It has been many times, that a problem that you consider unimportant can be the solution to your problem! Also, after you had the second failure, did you turn your computer off, wait 20 seconds and then turn it back on. Sometimes one digit hangs up and it requires a re-start. Thank you for considering our service and the choice you made... CONSTANTIN (arzconst)
Jul 05, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Nov 12, 2008 | 2004 Suzuki Verona
Breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Feb 24, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
71 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
