Question about Maytag Performance MHWE500V Front Load Washer / Dryer
My drum will not turn put the heater works - Maytag Performance MHWE500V Front Load Washer / Dryer
  • 822 Answers
Check brushes in motor........
cheers
Posted on Apr 05, 2011
When on spin mode the machine makes a terrible grinding noise and won't spin on 1200 speed Hotpoint Ultima WT965 7kg
Turn drum by hand, if you feel it catching, its something between the drum and tub, put in through soap draw usually by children. Can be removed by taking out the heater element to get access under drum.
If it feels rough all the way round when turned and it can be lifted up slightly ( free play ) then its probably the drum bearings and seal failed.
Oct 20, 2013 | Washing Machines
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Dryer does not dry all the time sometimes it dry fast other time you have to reset 2-3 times
You can put this machine into the field service mode to view the errors here is how to do that.
  • Turn the dryer on.
  • Go to the home screen.
  • Press help.
  • Press and hold my cycles and back simultaneously for 3 seconds.
Once done you can view the errors, post what it says. Note that once you exit this mode it will erase the errors so write them down.
Feb 28, 2011 | GE Profile Harmony DPGT750EC Electric...
How do I get the Malber all in one washer dryer to dry hotter. It seems to be getting cooler and cooler. It didn't use to be a problelm. I nolonger have the manual.
There is a wire which connects to a connection towards the front of the drum itself on the right side which when the drum wobbles, comes off. When it gets loose, it may start to arc so that the spade connector needs replacing. In extremis the whole unit may need replacing. This seems to govern whether the heater elements turn on or not. If you put the connector back on, I'll bet the heater starts to work again
Feb 03, 2011 | Malber WD1000 Front Load Washer/Dryer
Drum won't turn on my ariston ab1030c. I think the motor is working as it produces heat on the drying function. Tom.
The heater is produced by the heater element. The motor is working if it turns the belt so the drum will turn. Sometimes the motor is still good, but the relay from the push button is bad. In this case the circuit never enables the motor to turn, hence the drum is not turning. Need a service man, or if you are good with the schematic, there is one inside the controller from the manufacturer if you take off the real panel. Good Luck.
Feb 16, 2010 | Maytag HYE3658AY Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Drum will not turn
check the belt to make sure that you have it on right
Dec 26, 2008 | Maytag PYE2300AY Electric Dryer
Bosch Maxx WFL2061 Scraping sound when rotating the drum
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Washer wont spin belt came off put it back and tested on a spin but then it started making weird noises so we stopped it. turned drum manually but then drum jammed going one way but not the other
two possible causes. first - foreign object stuck between tub and drum. take heater out and you can peer into the gap between tub and drum second - bearings collapsed and im afraid this is the most likely cause. if memory serves me right, hotpoint supply a replacement tub and drum assembly at vast cost. lots of problems with bearings on the wma series
May 23, 2007 | Hotpoint WMA50 Front Load Washer
Maytag Performance MHWE500V Front Load Washer / Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
