Check to see if the Hot Water Supply Valve is turned on(where the Hose from the Washer is connected). If it isn't, turn it on. If it is, turn it off and unhook the Hose. Check the Screen in the End of the Hose to make sure it isn't clogged. If it is OK, turn on the Supply Valve to see if Water comes out. If it does, you may have a bad Water Supply Valve in the Washer.
