Question about Whirlpool Dryers
My dryer tries to start but doesn't. it only works when it wants to .when it doesn't it does nothing when i press start , or it buzzes then nothing
Ple read manual
Posted on Aug 06, 2008
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Aug 07, 2011 | GE Dryers
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
Kenmore 65611 electric dryer makes buzzing sound when press start but doesn't start drying process
heatman101
Jun 17, 2011 | Kenmore Dryers
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 31, 2011 | Dryers
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Dryer Start Button is not Working
sounds like the board may be faulty
Oct 24, 2008 | Dryers
Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Aug 14, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
