Question about GE TruVision DVR 10, 4-channel, H.264, 250GB
Using IE 9 I can't see remotely the cameras to my CCTV system. I believe the netviewer program is not working properly. I only get a small square in the middle of screen top.
Win7 has both Internet Explorer 32bit and Internet Explorer 64bit.Click on start, all programs, open Internet Explorer, NOT Internet Explorer 64bit. The shortcut on my desktop was to the 64bit option and I could not view cameras regardless of permissions etc. Once I opened 32bit version cameras work perfectly. I fought with this for weeks before realizing there are two versions of IE9. Hope this helps.
Posted on Aug 12, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 148 Answers
Hi just try this link
http://iefaq.info/index.php?action=artikel&cat=48&id=133&artlang=en
Posted on Mar 21, 2012
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
How to install activex manually?
To view your DVR remotely through the internet web interface, you must properly set your ActiveX controls in Internet Explorer.
First - Make sure you are not connected to or ar tying to connect to the DVR! Close the Browser and open a new one if you have to.
In your Internet Explorer browser, select the Tools drop-down menu above, and choose Internet Options. Choose the Security tab in the corresponding pop-up window that comes up.
[img src="http://asapcctv.com/software/standalone/img/SecurityTab.jpg">
Now click on the Custom Level button at the bottom of the Internet Options window. Scroll down until you see ActiveX controls and Settings, and apply the following changes:[img src="http://asapcctv.com/software/standalone/img/CustomLevel.jpg">
Follow the image below for the correct ActiveX Settings. (The settings as shown does not make your system more vulnerable, but maximizes your browser's security, while putting the choice of operation in your hands on a case-per-case basis.)
NOTE: These settings reflect versions 6-9 of Internet Explorer. Depending upon your version of IE, your controls may not follow exactly the same order or have all the options shown below -- Just make sure those you do have match what is shown.
[img src="http://asapcctv.com/software/standalone/img/ActiveX.jpg">
OK, and then return to your browser by clicking OK again.
Close your Browser and open a new one. You should now be able to install any ActiveX controls needed to run any DVR remote software.
Be sure to accept any requests for software installation after typing your DVR address into the browser address bar. There may be several controls to install.
Mar 25, 2014 | Dome 4 CCD CCTV Camera Surveillance...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
Mar 30, 2010 | Computers & Internet
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
Receiver not taking commands from the remote
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Jun 07, 2007 | Onkyo TX-DS989 Receiver
GE TruVision DVR 10, 4-channel, H.264, 250GB Logo
3,060 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
