SOURCE: Lacie usb 250gb Not recognized or found by PC
Right click on My Computer > Manage > Device Manager. Do you see any yellow exclamation points? If so, you have conflicting devices. I'd need some feedback at this point to continue to help you, but if you double-click on the yellow mark, a window will popup. See if you can troubleshoot or rollback some drivers.
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not
mounting on the desktop (Mac G4 Mirror), traced to the power supply
(57w) going down on power, both 12v and 5v supplies are available but
the main power to run the drive drops to below an adequate output,
hence the clicking and whirring evident from the drive with
simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit
got the drive up and running, however, and this is the reason for this
post, this lower power PSU failed a week later whilst waiting for a
warranty replacement from Lacie (5 weeks and still waiting for the new
PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test
with another Lacie PSU, do not run the drive on a lower rating (34w)
PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your
data to another drive and get the correct 57w power supply before
running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard
drive, they won't, fortunately I had a second back up, but am 2 drives
down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users
should do for long term security, as these do not seem to be very
reliable and getting warranty support from Lacie on these is currently
impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
SOURCE: Is my LaCie External USB 2.0 500GB fried/dead???
Does it make any clicking/clunking sounds like any of these?
If yes - it's really bad and there's nothing you could by yourself..
If it sounds normal or doesn't spin up at all then try to remove it from enclosure and connect directly to a PC.
SOURCE: lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
ATTNATION FOR ALL GUYES......
As a specialist in data recovery world, you know many reasons of data loss.
Drive not responding
Media Problem
Bad Secter
ALL Lose Data Recovery
Data imaged from a client's drive is useless
Hard Drive password protection system
Adaptives and more
Drive spin motor got stuck / burnt
PCBA damage
Bad sector
Firmware / ROM damage
Inexperienced & operation error
virus cause..
software program malfunction..
Forget the password...
Repairs your drive without losing the user data..
We Deals In Below This Hard Drives...
(1):MAXTOR
(2):Western Digital
(3): Seagate
Contect:
CEO : +92-346-7552499
Admin: +92-343-7551003
NOC : +92-42-6120826
_________________
«´¨`·. CEO M.Alam
..·´¨`»AD M.Munim
