On a Kenmore Oasis topload washer--model#11027082604-- washer still has F51 error code after replacing machine control board. Rene
  • 1 more comment
  • Rene Matz Apr 06, 2011
    Hi
    I believe according to Sears chart --F51 was possible main control board or a bad
    connection to motor.I cleaned connections but it didn,t help.Sears is going to send me a
    #W10183157.Looks like an electronic control with the wiring harness.
    Went on line & the F51 error code is quite common on the Oasis washers. some replaced
    main boards--some had luck with unplugging connections & re connecting.Has worked for
    me sometimes--not this one though.
    Will try this new wire harness. Rene
  • Rene Matz May 07, 2011
    Hi
    Replaced the rps kit & washer is running fine.Thanks for your info"" Rene
  • Anonymous Mar 12, 2014
    F51 error code kenmore oasis washer
  • Washing Mach... Master
  • 2,605 Answers
Hello, Welcome to FixYa. I can't seem to access any previous post dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. Sorry to hear you replaced the control for nothing, F51 has nothing to do with a control board issue. The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 06, 2011
  • Mark MacDonald
    Mark MacDonald Apr 06, 2011
    Hey Rene,
    Thanks for replying. If folks get the F51 resolved via replacing the control it's awesome, but the F51 99% of the time in my experience is associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS..
    There is a repair tip regarding this from sears ( I'm a sears technician myself ) which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
    Here's an exert from my files...
    The kit you're referring to ( part # 8565188 ) is as shown here and yes I've seen them, but mostly it is a loose rotor.
    You may want to check the rotor, but either way let me know how you make out with the repairs and good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald May 07, 2011
    Awesome, Glad it worked out. Hope you remember to rate the info I provided...that's kinda how the site works and I appreciate your support and value your opinion. Thanks again Rene.
    Regards,
    Macmarkus :)
I have a kenmore oasis he 262072 washer that has an f51 error
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Jan 05, 2011 | Kenmore Oasis HE 27062 Top Load Washer
Leaking and F51 error code on my Kemore Elite Oasis Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis F51 code - already replaced RPS. Now what?
Sep 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE is flashing a code
sound like the rps kit is required and is time comsuming will have to remove the back and console includes harness and new rps sensor and inset for sensor if not sure if you can perform it would be better to call service tech....must remove from the bottom of the motor location(main drive d/c motor)
Aug 19, 2009 | Kenmore Washing Machines
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE Model 110.27086603
Mar 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
