Question about Sewing Machines
Im trying to sew letters on thin fabric and lace. I think the grip is to ruff for the fabric. how do i fix this?
When sewing/embroidering onto lace, you will need a layer of stabiliser(Like mentioned above) for under your lace and a piece of water solvy on top of the lace, which washes away. For the best results
Posted on May 28, 2013
  • Sewing Machines Master
  • 1,129 Answers
You will need to have stabiliser behind the fabric to give it stability for any type of machine embroidery.
Look for a product called "stitch and tear" or "solvy" which washes away in water after you've completed the stitching.
Also, consider using machine embroidery thread for this task, its silky and gives a lovely sheen.
I've always used an embroidery hoop to hold the layers all together for monogramming so things don't slip.
I'd suggest you google "machine embroidery" or try www.sewing.about.com and see if there are other machine embroidery tips there.
Posted on Apr 06, 2011
I stitched a Tuscany Tablecloth and now want to launder and use. Is there any backing I can put on this to cover the stitching?
It would help if I knew what a Tuscany tablecloth exactly. Do you mean it is made of lace ? What fibre is it made from ? Cotton, linen, polyester, a blend, something else ?
If it is lace, putting a backing on it may not be needed. I'd place it into a large bag, like a pillowcase, unfolded. The case will protect it from a lot of rubbing. Presoak if there are stains.
I don't think I'd use a top loading washing machine because it may twist the fabric too much. Front loaders do not twist fabric around like an top loader does, so may be ok to use, on gentlest cycle, with cold water or just warm water.
Or send it to be dry cleaned instead, which can be the safest option for some delicate fabrics.
Oct 24, 2016 | Sewing Machines
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Jul 02, 2016 | Sewing Machines
When I tried hemming with thin fabric, fabric caught up under the sewing machine plate, then I forced to pull the fabric out. Since then machine is not working. Need an expert help,
You may have fabric jammed in the bobbin case...take the bobbin and the case out...watch how the parts go together as you remove them...look for bits of thread and fabric... A little lint brush with a pipe cleaner end is usually in your tool tray. Use that to sweep away dust etc... And when sewing very thin or fine fabric use tissue or tear away stabilizer to keep fabric from getting sucked into the bobbin case! Good luck!
Jul 11, 2015 | Sewing Machines
Janome problem feed dog won't "grip" fabric being sewed
adjust the pressure foot presser tension or try to raise a bit the feed dogs
Aug 01, 2014 | Janome Sewing Machines
Fabric get stuck in feed. I had to cut fabric then unscrew the plate and remove the fabric. This is Brother 1355
This happens to the best of us now and then, usually at the start of a seam with slippery or thin fabrics. If this is the case try to gently pull the fabric through by the loose threads at the start as you sew. Or start your sewing a bit further in from the edge to get a grip then sew backstitches carefully to fill in the space left.
Nov 03, 2013 | Sewing Machines
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
Embroider Long names using Memory Card 101
I think you have to rehoop the fabric. Especially if the letters are large. Hope you have a clothsetter - it makes it so much easier. Hope this helps.
Feb 18, 2010 | Janome Memory Craft 9000 Computerized...
I have a Kenmore 19606, I have never own a machine that does embroidery stitches, the pattern of the stitches shows on the wrong side of the fabric not the right side. Is this suppose to happen? If not how...
Not sure if you are doing embroidery w /a hoop and all, which I don't do but I have lots of decorative stiches . Ytp lacing some tear away interfacing below the fabric you are going to sew. Most stitches come out top to bottom. Say I have an alligator option. Image will be about 1 1/2 inch , Try it on a piece of scrap fabric to start. I used muslin and the tear away bnacking to stabilize the design on lettering and patters.Also use good thread. I like Guttermans. Coat and Clark / Sulky are very fine and snag and tear easily. Good luck. Keep trying. The design you sew will show on both sides , so if you do not want that you will have to add another level of fabric to the backside after completing the design. Hope that makes sense.
Mar 29, 2009 | Kenmore 19606 Computerized Sewing Machine
Sewing Machines Logo
95 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
