Question about Bose Aviation Headset X Headset
The yokes on a BoseX are breaking again they last about 4 yrs in airline service. Bose will not sell the yokes you have to send in the headset for $175.00+ to overhaul the headset. Any after market replacements? RJflyer
Attn: Rofel Lantican Dear Rofel, You helped me on another problem approx. 4 months ago. Anyway I just purchased a Bose Solo 15/10 Sound System.
Sorry Kelly, I'm not the guy who helped you before; but, yes there are and many different kinds. Some easier and some harder to use, in fact there are even kits to build your own.
Search eBay for Bluetooth, receiver, you'll need one with an amp, if the Bose doesn't have one built in. But, otherwise, they're just like paring any other bluetooth device, like a headset, only with these, you don't need the speakers in the headset. In fact, if you bought a cheap bluetooth headset, and the Bose had it's own amplifier, you could wire the headset speaker wires directly to the speaker inputs of the Bose, if you know how, and you might just have a really cheap one!
Good luck, and let me know if this helps!
Sep 03, 2015 | Bose Radio Communications
How to fix the sound on the Bose Solo TV system
Contact the authorized service center for Bose. The fault is with its audio output amplifier section circuit. Normally, it will be difficult to get spare parts to this set at local electronic spare part market.
Gopakumar Gopalan Google
Jun 09, 2015 | Bose Solo TV sound system - Black
How can I fix connection problems with Bose Series 2 Headset? My Bose Series 2 bluetooth keeps dropping and reconnecting to my iPhone 4s on the last IOS update 7.x ... how can I fix?
Hello. I gave one of these as a gift to my friend and he had the same problem as you. I google EVERYTHING, and the Bose website states they manufacture products that are made to last, and if you have ANY problems you should contact them. What I found is there are software updates for your headset (go figure), and I think if you register with them they will email you when that happens. I know this will work because even my friend was amazed (he was ready to throw his away). This is the link to the page that will lead you to the software updates for both mac and windows:
http://worldwide.bose.com/downloads/en/web/bose_bluetooth_system_overview/page.html
Jul 28, 2014 | Bose Bluetooth Headset Series 2 - Left Ear
BOSE BLUETOOTH SERIES 2 DOES NOT TURN ON....I CHARGED IT AND IT SHOWED IT WAS CHARGING AND AS SOON AS IT IS DISCONNECTED THE LIGHT GOES OFF
Bose states they build their products to last and they have excellent product support. This is the link to their customer service:
http://worldwide.bose.com/productsupport/en_us/web/bluetooth_headset_series2/page.html#listview=function_troubleshooting&article_type=view_article&article_href=/productsupport/en_us/web/troubleshooting_bt2_pairing/page.html%3Fproductlabel%3Dbluetooth_headset_series2%23article_body&tab=contact_tab
Feb 19, 2014 | Bose Bluetooth Headset Series II Right Ear
Bose Bluetooth Headset Series 2 - Right Ear
What exactly happens when you say the battery drains fast? Does it suddenly stops working, or does it starts beeping with low battery notification right away?
If the battery is bad, then you will need to have it replaced. Although the bluetooth is made to be a single piece without easy way to service it, it can be done, although with some skill.
One day I will post detailed instructions on how to service this type of device, but from what I know these types of posts BOSE corporation takes down very effectively, that is why you do not see any of them.
If the bluetooth suddenly stops working and then starts up again, that most likely is a actual switch problem, and requires cleaning inside the switch. I say cleaning instead of replacement, because I failed so far finding switches of this type. It is about .7 mm high, about 5 mm long and 2.5 mm wide. If you are careful, you can open the switch, clean the inside moving parts of it, and solder it back up again. I have done so with at least 20 of them, so I know it is doable.
Oct 28, 2012 | Bose Bluetooth Headset Series 2 - Right...
The airline i travelled with yesterday broke the top bar of my quinny zapp (the piece that pushed in between the handles! two days earlier they broke the zip on the travel bag! i reported the broken bar...
Good Evening
Unfortunately this section (the hand grip connector bar) is riveted in place and there is no quick fix. Are you a UK customer? If you own a pop rivet gun you could order a replacement to fit yourself, however we'd have to allow 14 days for delivery (standard 1st class Royal Mail). Alternatively you can send the chassis to our engineers for them to carry out the work. Standard cost if you send it back for our engineers to do is £60, and this does include return courier service back to your address, however you'll need to make arrangements and cover costs for the unit to be sent into our engineers via courier. It would be worth contacting the airline customer service department and asking them what provisions they have in place for this sort of incident, as they may be able to deal with it direct for you.
May 23, 2011 | Quinny ZAPP Stroller
Led readout faded and too faint to see
I just tryed to get a part today for a Wave Radio. Docter Bose told me they don't sell parts in the field for there Units. They said I can send the Radio and $99.00 and the will make it like new again. Woopie
Oct 08, 2010 | Bose Wave Radio
Bose Aviation headset Series 2 has high-pitched squeal.
Try wearing the headset the "wrong way". The left side of the headset on your right ear & the right side of the headset on your left ear. I have the QC15 with the same problem and it worked for me. Good luck!
Jun 03, 2009 | Bose Aviation Headset X Headset
Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Apr 01, 2009 | Bose Lifestyle 12 System
Bose Aviation Headset X Headset Logo
105 people viewed this question
Top Bose Radio Communications Experts
 Grubhead
Grubhead
DIY-Dan
Level 1 Expert
Owen Barnes
Are you a Bose Radio Communication Expert? Answer questions, earn points and help others
