I need to know the compatible RAM Memories of my motherboard HP 410716-00. I Don't know!
  • Brian Sullivan
    Brian Sullivan Apr 05, 2011
    is these correct details of your motherboard HP 410716-00
  • fanypr_14 Apr 06, 2011
    I found this page:
    http://www.hypermicro.com/PrintItem.aspx...
    The motherboard code is 410716-001. you think that this page can help me?
    I need to find it because I need one RAM Card and I bought a wrong card. :(
  • 27,725 Answers
I need help for motherboard gl-81915pl-g.I put 2x2gb memory and not work.i have 2x1 gb and work.Pls Help me.
Motherboard don't use any types of memories from any manufacture. Check the documentation of your system and verify that the memory that you installed is compatible with your system. When you start up you system you probable get a loog beep from your computer speaker.
Mar 30, 2012 | Gigabyte Computers & Internet
Hello Folks, I'm in dire need of help. Nowadays
Hi Joseph.
The Asrock motherboard has 2 memory banks each supporting 1GB PC2100 (DDR266) / PC2700 (DDR333) memory modules (2GB) in total.
I would recommend that you purchase the PC2700 (DDR333) memory because its a little faster than PC2100
The HP memory that you posted a link to will not work as it runs at 400MHz (PC3200) which is too fast and the motherboard doesn't support memory that runs that fast and is the same with the other link too. In both cases you are paying through the nose as you can get DDR ram much cheaper than $118 dollars.
I would recommend to you Kingston Valueram. It is much cheaper and runs very well. You can also get this RAM at Walmart!! It cost around 45 dollars which is a saving of over 80 dollars.
Right click on the link I have provided for you below and open it in a new tab or window, you will nicely surprised at what you see
http://www.walmart.com/ip/Kingston-ValueRam-1GB-PC3200-DDR-Desktop-Memory/13996893
Good luck and if there is anything else please post back.
Leecom72
Jun 09, 2011 | Computers & Internet
I have 512mb memory and it doesent work but two 128 mb memories work properly
Either your 512 MB RAM is not compatible with your motherboard or it is damaged in some way. RAM is very susceptible to static electricity. Check that your 512 MB is compatible first (ie: DDRx and the MHZ). If it is then the stick is bad it sounds like.
Sep 21, 2010 | Gigabyte GA-6OXE-1 (GA-60XE-1) Motherboard
RAM compatibility HELP
Yes this pc3200 is hardly compatible, because your motherboard is supportable of DDR 1 type RAM, Hence th PC3200 = 400 MHz, so you can add this ram to your PC, such that the ram which is between 266mhz to 400 MHz is absolutely a DDR1 type . please dont forget to vote for me.
Jul 10, 2010 | HP Computers & Internet
DELL OPTIPLES GX280 (E219542) MOBO, MID TOWER
Several long beeps means there is a problem with the memory. First of all make sure the memory is seated in the slot perfectly. There should be no movement whatsoever when you gently try to rock it side to side. If it still persists the bad news is the memory is most likely shorted out or defective. They are VERY sensitive to static electricity. I would go ahead and put the old memory back in for now and send the new defective memory back. Most vendors will issue you a replacement free of charge if you let them know it's not working.
Hope this helps!
Mar 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
I want to get a new mother board for my toshiba satellite A105-2001
for you laptop motherboard all you need is to give you supplier the model number of you laptop and they should be able to supply you with the exact, right motherboard because laptop of the same series will carry the same motherboard, the only difference might be the chipsets, but all your other hardware will be compatible to that motherboard. This is your model number you need: Toshiba Satellite A105-S2001
Jun 06, 2008 | Computers & Internet
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
