Question about Philips Audio Players & Recorders
I have aphilips cdr785. When ipuy a blank dics in the recorder tray to burn a cd it keep telling me to insert a disc. I inserted the right disc a blank audio dics.
  • Philips Master
  • 6,993 Answers
how long have you been using the player and has it ever accept blank discs in the past?
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing CDs, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play. If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty discs such as CD +, CD -, CD RW. Try any of this empty CDs as one of them as to be compatible with this CD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Posted on Apr 05, 2011
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
Cd not recording
Be sure to "finalize" the recorded cd before use in another cd player. Another thing is there are always a few bad discs in a spindle of blank discs... And sometimes you will get "check disc" or "bad disc" when a blank disc is inserted. I would be sure to use blank discs for audio use, not computer use, with your Yamaha.
Apr 14, 2010 | Yamaha CDR-D651 2-Disc CD Recorder
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Recording problem
try using + AND minus blank discs maybe it wont accept cd minus r CD - R Discs so try CD + - R DISCS
May 28, 2009 | JVC XL-R5010 4-Disc CD Recorder
Recording problem
Does it stop at the same time elapsed on the CDr every time? Can you resume recording on the same disc afterwards? What about if you dubb high speed from the internal player?
Jan 12, 2008 | Philips CDR785 3-Disc CD Recorder
Cd burner
You may want to double-check the "error" message. Normally, when you insert a blank CD-R or CD-R/W you'll see a pop-up message that says something like, "you've inserted a blank CD. What program do you want to use to put something on it?" And then it will give a list of programs like Windows Media Player, Nero Burning ROM, Roxio, MyDVD, etc. The last two choices are "Open a writeable folder" and "Do nothing." The next to last, the open folder, option is the CD recording option for Windows. Once you've put copies of that data into the new window click on the "burn these files to disc" link on the left side or located under the File menu at the top of the window.
Now, if it truly is telling you that you have to insert a blank CD, then you may have one of two problems. Either the CD you're putting in is NOT actually blank or the drive is having problems recognizing the media. To test the first scenario, try the disc on another computer. If it's truly blank, then try uninstalling the CD burner from your Device Manager located in the Windows control panel. Double-click on the System icon > Hardware tab > Device Manager > click on the (+) symbol next to DVD/CD-ROM drives and then highlight your Sony CD burner > right-click and in the menu choose Uninstall. Reboot your system and let Windows redetect the drive and reinstall the drivers (You may want to have any install discs handy, just in case Windows asks for them, but not likely).
I hope that helps!
Nov 08, 2007 | Computers & Internet
Recorder not recognizing blank media
To fix this problem, buy CD-R Blanks with word MUSIC CD-R MUSIC
Aug 28, 2007 | KLH CDR2000 2-Disc CD Recorder
Blank dvd media is not reconized
1.Please cheack weather the DVD meadia is DVD R/W combo drive, 2.Then only the DVD media will be Burn or write tO the Blank dvd media & then check weather the blank cd is a dvd r/w cd.
Jun 29, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
75 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
