Question about Karcher 2500 PSI Pressure Washer
No pressure craftman, 4.0 hp, 2150 psi, 1.9 gpm, everything works and is on, but no pressure at all, please help....vicky
  • Anonymous Aug 08, 2008
    1. no pressure
  • 14 Answers
Replace the bypass valve, this is the most common problem. Failing that remove high & low pressure valves and ensure they are not blocked or worn
Posted on Mar 11, 2009
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
I need a manual for a shop force 2000 psi pressure washer. It is 1750 working pressure. It has 2.4 hp ohv engine. 1.6 gpm
I have a question because I am using a gas pressure washer more long time but I want to use electric pressure washer so please tell me something about the best electric pressure washer. http://car-gears.com/
Jul 28, 2011 | NIB Shop Force Universal Pressure Washer...
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
No water pressure
There is a injector valve in the water pump that is sticking. Remove this valve, grease the top o-ring and reinstall. Problem solved. Use pump guard in the future to prevent this problem from reoccuring.
Mar 22, 2009 | Karcher 2500 PSI Pressure Washer
Craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Jan 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
240 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
