Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
On my proheat bissell carpet shampooer the brushes are not spinning
  • 710 Answers
Did you check the belt(s)? If the belt isn't broken, see if it's stretched. Also, check to see if there is debris keeping the belt or brushes from turning. Sometimes, a piece of string will get caught and cause the brush to stop.
Give these things a try. Good luck,
If this isn't the problem, please reply back and I'll try to get you more information.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 05, 2011
  • yentnabunny1 Jul 31, 2011
    I replaced both belts and the pivot arms,,,the brushes turn briefly then stop- it's like the brushes are dropping to low to floor. Have checked all screws and they are all tight!!! Not a happy camper right now :(
  • MandL Jan 04, 2013
    the main pump belt is prob stretched. Check by slipping off main belt from motor pinion(shiny drive shaft ) then press firmly onto semi-spherical pump pulley. Then try rotating brushes..if the brushes will not turn, the secondary (ridged) brush rotor belt is ok. Now slip the main belt back on to its shaft and press on the shaft (not the belt) with a screwdriver etc. Try spinning the brushes again and if they spin with little resistance against a stopped shaft, the belt is slipping and will need a replacement. In the UK try Espares and it is a good idea to get another spare and a spare secondary belt as these snap eventually and always half way through a job.
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
I have the bissell carpet shampooer, I need to remove the brushes to clean it but don't know how
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
mn,n
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 8910 Proheat brush falling
heatman101
upo;
Mar 17, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
407 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
