Question about Rheem Water Heaters
I have a rheemglas standard electric 40 gallon water heater and the hot water in the shower or any where in the house only last 3 maybe 4 mins.....?
  • 20 Answers
You should have two panels on the front of your water heater most likely painted blue. Each of these panels contains a heating element. The top panel contains the reset switch. Unscrew and remove the top panel and you'll see the reset switch - it is the red button. Press it to see if it clicks. If so, your hot water should last longer.
If it does not last longer than you stated, then you most likely have a bad heating element. The problem is that unless you remove both elements, you won't know which one is bad. If you don't feel comfortable turning off the water valve to the heater, turning off the power to your water heater at the circuit breaker box, draining the heater of it's water using a garden hose, removing the wires from the elements, removing the elements and installing new ones from your home improvement store then you may want to hire a plumber to do it.
The process is fairly easy but time consuming. The most time is draining the water heater. If you do choose to do it yourself, you will need to get a special "wrench" from your home improvement store to remove the heating elements first. The store can help you with the element(s) you need once you take them in.
Regards
Posted on Apr 05, 2011
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For money-saving water heater information:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
We have a Rheemglas Standard Electric Water Heater 81V400 B and it's leaking water from the tank and also the hot water only lasts for a short period of time. I've been reading and have read that the water...
if your water heater is leaking from the tank, and not around any fitting, then you will need to replace the heater.
you can flush the heater, once a year is always recommended, however once every 2 years is sufficient.
scale, and deposites inside the tank will cause erosion and eventually eat through the walls of the tank. not much you can do to prevent this. the steel in the new tanks just don't last like they ued to.
Sep 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need help
I would use the instant unit for a secondary unit to a large conventional heater, 40 gal min, gas or electric. They are both about the same now, but when the power goes out, you might not have the pump running, but you will have hot water! And whether it is a secondary or a primary water source, you will have a hot supply feeding it just in case. We have 2 people in the house, and a 30 gallon unit, and it is not big enough. The 40 gallon tank worked great. Hope this helps.
May 04, 2010 | Bosch & Tankless LP Hot Water Heater
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Lack of hot water from water heater
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
This has been a small manufactor recall on this matter
Please rate Thanks
jj505
Mar 29, 2009 | Whirlpool Water Heaters
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Water Heaters Logo
862 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
