Question about Hoover Vacuums
My hoover, self propelled windtunnel ,on off switch will not shutoff. the second the electrical plug is put in the wall socket, the vacum starts running and you cannot shut it down with the on off switch
  • Handie Andie
    Handie Andie Apr 05, 2011
    Has it worked before or is this a new cleaner?
    Thanks,
    Handie Andie
  • 294 Answers
SOURCE: Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Posted on Feb 28, 2009
SmartAlec
  • 171 Answers
SOURCE: why is self propelled not working on my hoover windtunnel
Hi there SmartAlec from Nelsonvacuums.com.au here. Actually the brush belt needs to be tight as well for the self propell function to work. However once you change that if it is still not working it could be the drive mechanism itself. You can test this by laying the vacuum flat on its belly so you can see the brushes. Turn it on and push the handle down (as if you were actually vacuuming). This should get your drive wheels going they are two wheels about 3 inches away from your brushes. If they are not turning then you need a new drive mechanism. If you are in australia i can get you one through our website above.
Hope this helps. Happy Vacuuming :)
Posted on Sep 03, 2009
  • 18 Answers
SOURCE: hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Posted on Oct 08, 2009
  • 18 Answers
SOURCE: Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
  • 11 Answers
SOURCE: HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Posted on Oct 22, 2009
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
Hoover Windtunnel repair manual
click this link below to see repair video for self propelled mechanism
http://www.youtube.com/watch?v=K722IsUxjYM&feature=related
Sep 03, 2012 | Hoover Vacuums
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
It just stopped running.
This most likely is your electrical switch on the vac. you will need to take it in for repair. simple cost effective repair
Oct 26, 2009 | Hoover Vacuums
Hoover windtunnel self-propelled - will not turn on
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
215 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
