Question about NEC MultiSync Computers & Internet
I have a NEC MultiSync E1100+ monitor that starts up ok with a great picture but after about 2 minutes the entire top half of the screen goes black. The remaining half displays correctly. Sometimes it will snap back to a correct display but will only last that way for a couple of minutes, and the top half goes black again. The monitor was purchased new in 1999 and this problem started about 9 months later. I have had the monitor in storage because none of the shops in my area would even look at it. It was almost $500 new so I have been reluctant to discard it, hoping that someday I could find some way to get it fixed. I have 3 of these monitors, two of them have been working without problems since I purchased them in 2000.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • NEC Master
  • 1,633 Answers
Connector problems
Posted on Mar 26, 2017
3 Suggested Answers
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
byteguy
  • 2229 Answers
SOURCE: nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Posted on Aug 28, 2009
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Nec Multisync LCD 195VXM+ black screen after turning on computer
Aug 28, 2009 | Computers & Internet
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Remove the back on NEC LCD 2010X
Remove the 2 screws from the bottom of the screen at the back of the monitor. Half way between where you removed those screws use a flat tip screwdriver or similar to push the back plastic shell in & up to release the clip holding the 2 parts together. Similar clips also hold the top sections together. Good luck
Mar 19, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
NEC P1250+ hisses and scrren blips intermittently
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Sep 19, 2007 | NEC MultiSync P1250 Plus (White) 21" CRT...
Computers & Internet Logo
112 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
