Question about Dexter Bowling Mary Dark Taupe Bowling Shoes for Women
The slide pad is coming off of the bottom of the shoe
  • 27 Answers
Use some Gorilla Glue to stick it back on. Works like a charm!
Posted on Jun 30, 2011
Every thing appears to be back on properly except the drum will not slide over pads
if you have the correct shoes than make sure star adjuster at bottom is all the way in and slide drum over than use a brake spoon to adjust
Aug 03, 2015 | Cars & Trucks
How to replacet rhe frount break pads
Their is a flat head screw on the callipar. Unscrew it first. Inside of the flathead screw is an allen wrench nut. Break the allen wrench nut loose. Now unscrew the two bolts that hold the calipar in place. Remove them completely. Slide the calipar off from the disc. Finishing unscrewing the allen head nut that we talked about earlier. Pull it all the way out. Remove the shoes unless they fall out.. Easy to take out.. Blow off the calipar. Replace the shoes. Now put that Allen head screw back in that holds the shoes in place. No need to tighten it yet. Just snug. Spread the shoes apart by using a screwdriver being careful not to damage the pads. Large screwdriver. Slide the calipars over the disc and now put some locktight onto those two mounting bolts for the calipars. Tighten to about 40 lbs. Now tighten the allen set screw that holds the shoes in place. Replace the flattip screw that covers the allen head. Use a impact driver to tighten by hitting it once. Pull on break handle about 4 times to set the shoes to the disc. Do this before you start your bike.. You have brakes.. It was easy.. Way to go!!!
Jan 30, 2011 | 2004 Honda VT 1100 C2 Shadow Sabre
Tools required to change brake pads on 2003 impala
Removal & Installation
  1. Siphon 2 / 3 of the brake fluid out of the master cylinder.
  2. Mark the relationship of the wheel to the wheel stud for re-installation purposes. Remove the tire and wheel assembly.
  3. Install 2 lug nuts to secure the rotor in place when the caliper is removed.
  4. Install a large C-clamp over the top of the caliper housing and against the back of the outboard shoe. Slowly tighten the C-clamp until the caliper pistons are pushed into the caliper bore enough to slide the caliper assembly off the rotor. Use care not to tighten the C-clamp too far or the outboard shoe retaining spring will be deformed and require replacement.
  5. Remove the caliper mounting bolts and remove the brake caliper from the mounting bracket.
  6. DO NOT disconnect the brake hose from the caliper or allow the brake hose to support the weight of the caliper. Support the caliper on a piece of wire out of the way.
  7. Remove the outer brake pad from the caliper using a suitable prying tool to lift the outboard shoe retaining spring so that it will clear the caliper center lug and pull the brake pad out of the caliper.
  8. Remove the inner brake pad by unsnapping the shoe springs from the piston.
To install:
  1. Clean all parts well. If the brake pads were worn so badly that the brake rotor is damaged, it must be replaced. Light scoring of the rotor surfaces not exceeding 0.060 inch (1.5mm) in depth is not harmful to brake operation and may result from normal use. Brake rotors may be refinished. Do not use a rotor that, after refinishing, will not meet the thickness specification cast in the rotor. Always replace with a new rotor.
  2. If not done at removal, now use a C-clamp and clamp both pistons at the same time with a metal plate or wooden block across the face of both pistons. Take care not to damage the pistons or caliper boots.
    NOTE After bottoming the pistons into the caliper bore, lift the inner edge of each caliper boot next to the piston and press out any trapped air. Make sure each boot convolution is tucked back into place. Boots must lay flat.
  3. Inspect the caliper bushings for wear. Replace as necessary. Carefully inspect the slide bolts for corrosion. If corrosion if found, use new parts including the bushing assemblies when installing the caliper. Do not attempt to polish away corrosion. Lubricate caliper slide bolts with silicone grease.
  4. Install the new inner disc brake pad in the caliper by snapping the shoe retainer springs into the piston making sure both sets of locking tabs are seated in the caliper pistons. The pad must seat flat against the pistons.
  5. Install the outer pad into the caliper by snapping the outboard shoe retaining spring over the caliper center lug and into the housing slot. The pad will slide up onto the caliper and the retaining ring will lock into place on the groove in the caliper.
  6. The outer pad wear sensor should be at the trailing edge of the shoe during forward wheel rotation.
  7. Install the caliper mounting bolts and torque to 80 ft. lbs. (108 Nm).
  8. Remove the 2 nuts temporarily securing the rotor.
  9. Install the tire and wheel assembly and tighten to specification.
  10. Pump the brake pedal several times to seat the pads against the rotor.
  11. Check the brake fluid level and top off as necessary.
  12. Road test the vehicle to ensure the proper brake performance.
Good job (remember rated and comment this).
Sep 10, 2010 | 2003 Chevrolet Impala
How to slacken rear brake shoes to replase disc
Hi Ricky
Your car has disc brakes so you need to release the brake pads not shoes (they are for drum brakes). That should help when you buy a new set.
Loosen the split pins which hold the pads in the caliper. You should then be able to push the pads out. It sounds like the pads are worn down so much that the caliper pistons are at their full reach.
Once you have slid them out, you need a piston retractor tool to push the pistons back in the caliper in order to be able to fit the new pads.
SLide the pads in, use copper grease on the back surface to stop them squeaking. Once done, pump the brake pedal to set the pads and the job is finished.
Aug 21, 2010 | 1994 Saab 900
The bottom section came off, (the plastic fingers that clean. How do I reassemble this onto the main body? Many thanks.
You will first need to replace the pool cleaners foot pad. Press down on the locking tab while pulling
the foot flange toward you and up. It is important to note that if the threads of the pad are 1/8" or less, you should go ahead and replace it also. You should then be able to slide the flap into place on the foot flange and replace the foot pad. Slide locking tab into position and push down on the shoe to lock it into place.
Aug 19, 2010 | Zodiac Baracuda G3 Automatic In Ground...
How do I disassemble a dremel shoe polisher? thanks
take the 4 screws out of the bottom and take the plate off. then take the 2 screws out of the the actual polisher unit. also take the 2 screws out of the button connector thing. after that remove the electrical caps to all the wires and untwist the wires and take off the polisher unit. heres the hard part. get strong pliers or a strong gripping tool and grab hold of the metal securing covering the motor. rip the metal were it comes around and meets and once you have done that (it will take a while), the whole metal covering will come off. next you have to take the polisher pads off and untwist the plastic cones underneath the pads. now you need needle nose pliers and you will have to untwist the 4 nuts on each side with the pliers. once you have done that you can take the nuts off and slide the black motor coverings and you are left with the motor and you have disassembled the Dremel Shoe Polisher.
Aug 27, 2009 | Dremel Tools & Hardware - Others
Cant fit drums over pads
You need to retract the brake shoes, via the center adjuster mechanism. As your old brake wore, the adjuster moved the shoes outward. Simply move the adjuster to retract the shoes, then slide the drum on. Then, readjust the rear shoes.
Mar 15, 2009 | 2003 Toyota ECHO
Seized brakes shoes.
TAKE A BLOCK OF WOOD AND A CLAMP USE THE CLAMP TO COMPRESS THE PISTON
Mar 08, 2009 | 1998 Dodge Durango
Clicking sound coming from the driver's side rear by the tire
We just recently purchased a 2000 Expedition. It is wonderful shape but it has started making a ticking noise from under the hood , when you start it. Can anyone help us?248c23f.jpg
Dec 26, 2008 | 2000 Ford Expedition
Dexter Bowling Mary Dark Taupe Bowling Shoes for Women Logo
Top Dexter Clothing Accessories Experts
Da Doc
ray gallant
Are you a Dexter Clothing Accessory Expert? Answer questions, earn points and help others
