Question about Viking DFB450 Dishwasher
The three lights for Pots & Pans, Normal Wash, Econo Wash are all flashing. When I hold the start button down for four seconds, just the Normal light is on. However, once I close the door, all three lights are on again, and the dishwasher does not start. We have tried unpugging it and then plugging it in again. It worked once then went back to all three light flashing. Before this, only the Normal Wash and Econo Wash lights were flashing.
  • Viking Master
  • 2,605 Answers
Hello, Welcome to FixYa. I can't seem to access any previous post dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. The scenario you describe is usually associated with a drain problem/back-up or overfill situation...if it is indeed the Viking (built by Asko) DFB450. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 06, 2011
Tip
Thank God for smart people and information on the internet!!! We just moved into...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Oct 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool du1055xtss3 not working
I dont know if this indicates a malfunction or not. One user manual may cover several years while many modifications can take place. Ask yourself if any other part of the process can contribute to this. You have electricity to the control board or it will not flash these display indicators.
Is the water on?
Is the waterline kinked under or behind the machine?
Is it connected to hot water? A heater raises the hot water quickly but cold water takes alot longer to reach operating temp. Since the hottest program id pots and pans, this may indicate the heater is bad but since you were able to change the display to pp and normal I think you entered into a controls sequence that technicians can do to make changes to some parameters like temperature setting or water hardness. See if you can get a whirlpool tech to break the grip on his service manual and send you a page by email. Good luck.
Apr 23, 2013 | Dishwashers
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwasher will not start..we've had it about 3 to 4 years
Some of these units have a thermal fuse in line with and mounted on the control card. This will need to be checked. Also check the door switches. Some models will aloow power to the control card but to nothing else.
Oct 12, 2007 | Kenmore 16872 Built-in Dishwasher
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Viking DFB450 Dishwasher Logo
349 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
