Question about Car Audio & Video
Hello i have a brook stair lift supreme ser..619133 at the top of the stairs and need to get it down .Is there a amanual release if i disconnect the power
  • 1462 Answers
SOURCE: How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Posted on Sep 25, 2008
SOURCE: wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Posted on Oct 16, 2008
  • 2336 Answers
SOURCE: Stair stepper won't start
Wide Ride Pedal CTGID0 Stair stepper won't start
Posted on Dec 01, 2008
  • 192 Answers
SOURCE: staying connected to the internet
if you are up to it you might wont to swith to verizon Fios they have same things like chart that includes internet, tv, and phone. There modems are easy to set up all you have to do on there modem is enter the ip adress enter the defalt user name and password and change it to one you can remember and you would be online. One other thing most of there routers have built in wirless network asses which is protected by a WEP password which is located on the botom of the router.
To check if you qualify go to www.verizon.com and lock for there to enternet choces you wold need to enter you home phone # or adress to see if it is avaliabe.
i hope this would help.
Posted on Jan 04, 2009
ask fred
  • 29 Answers
SOURCE: handle one siad keeps colapsing so unable to go down
you need to have your chassis repaired by www.buggypitstop.co.uk we repair and service bugaboos
Posted on Apr 29, 2010
My mums stairlift 120 seat is stiff to rotate at the top of the stairs. Can the bearing be lubricated.?
hi Andy, the lever you pull or push down to rotate the chair is it bent ? there is a type of washer so with care spray WD40 or GT85 some in that area but be careful because behind and under the plastic is electronics etc.
Regards
Rob
Feb 03, 2018 | Health & Beauty
Where can I get batteries for a stair lift?
Try 'Batteries Plus' if you have one locally. Other wise I would go to the internet and enter the battery data into a Goggle search - Amazon (my choice) and eBay can be two specific places to search.
May 20, 2014 | RTO Stair Glide Outdoor Stair Lift
Repair person
check in your local phone book for a stair climber lift service in your area.
May 02, 2014 | Exercise & Fitness
Savaria stair lift
when we push the buttons to move it up or down it just makes the noise that it does when it starts to move but it does not go. Light on on the chair. Changed batteries in controller. HELP
Feb 02, 2014 | Medical
How can I disassemble whirlpool elite dryer to cary it through 25 inch wide stairs and reasseble on new location
It's a many step process. you remove the control face disconnect the wire harness on the left by the capacitor, push in on the lock and down to release female side, remove the clear pressure switch hose on the right, then go to the back and looking at the back remove the brace arm hex screw on the right remove brace cover and pull down the wire bundle. Remove the hex screws on the corners holding the white metal corner to the brace should be 4 should be able to lift the top from there give or take a few screws. good luck
May 07, 2011 | Whirlpool LSB6300PW Top Load Washer
Dyson Dc07 dustbin will not release
USUALY REMOVING THE 3 TOP SCREWS COMPLETLY YOU CAN NORMALY LIFT OFF THE TOP WITH EASE.
IF YOU CAN DO THIS REMOVE THE ROD TRIGGER ASEMBLY FROM THE TOP AND THEN PLACE THE BARE ROD BACK INTO THE BASE WITHOUT THE TOP AND ALIGN THE ROD TO THE TRAP DOOR LATCH AND GENTLY PUSH DOWN WITH SOME PRESSURE AND WITH A BIT OF LUCK SHOULD RELEASE BOTTOM FLAP IF SUCCESFUL WASH BOTTOM LATCH ASSEMBLY WITH HOT WARE AND REMOVE DUST & DEBRIS AND REASSEMBLE,
Apr 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Attaching the attachments
Take off the brush that is on the end of the hose, then attach your stair cleaner on the end of the hose.
Sep 23, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
