Question about Chamberlain Power Drive 1/2 HP Chain Drive Garage Access System - Garage Doors &
Two identical openers running two side by side doors. One opener works with remote up to 100'. Other sometimes works that far with remote, often needs remote to be within 20' to function. Is the "pot" on the interior logic board a "gain, distance" adjustment ?
    Genius:
  • 1,126 Answers
You are right that should change the gain of the frequency and give you a longer range, only a **** adjustment should fix it..
Posted on Apr 06, 2011
2005 Chevrolet Trailblazer that the key won't unlock the door on. I don't have a remote. How do I get it open with breaking a window
I think you mean How do I get it open WITHOUT breaking a window.
Did you try the passenger side or back door?
Any locksmith with the right equipment should be able to open it. If you live far from locksmiths, the Police may be able to help you, sometimes they carry thieves tools to legally get into vehicles.
Nov 19, 2016 | Chevrolet Cars & Trucks
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
I have a Sears Security Keyless remote entry device that mounts on exterior of garage to allow me to open the door. It is model 139.18795. That is no longer listed as a part at Sears but an identical...
The motors in a garage door opener are under quite a strain and will not run too much without overheating. The thermal overload will cut them off until they cool. This could be your problem. The model number of the opener is on the end of the motor unit nearest the door and you need that to make sure you have the right keypad. There are more than one and some will not work.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
The Hatch window on my 2002 Astro Van won't open?
To start with , stick the little red nozzle from WD-40 in the key slot as far as you can & spray real good in there. Can you hear lock "thump" when you hit remote for unlock, or open?
Apr 09, 2009 | 2002 Chevrolet Astro
Door wont close all the way
NOT SURE WHAT UNIT YOU HAVE .
ALL OPENERS HAVE AN ADJUSTMENT TO TELL IT HOW FAR TO GO UP AND HOW FAR TO GO DOWN. LOOK ON THE SIDE OR UNDER A LIGHT COVER.IT HAS TO BE THERE SOMEWHERE
Nov 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
The refridgerator door of my Whirlpool side by side refridgerator/freezer is not closing properly. I checked for any obstructions including possible deterioration of the magnetic strips. It acts like the...
look closly at bottom of door there is a metal door stop, screwed to bottom of door, that prevents door from opein too far. Well when the door is forced open too far the door stopbends sdn then actually prevents door from closing all the way, you see it hitting the hinge(if indeed this is your issue), to repair it either simply bend it back staight witha pair of pliers, or what i sometimes do is switch the refrig and freezer door stops.They are identical, but only require the use of one side, (1 stop will do either door just depends on position as to how it operates)
Mar 09, 2008 | Refrigerators
Chamberlain Power Drive 1/2 HP Chain Drive Garage Access System - Garage Doors & Logo
95 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
