Question about Boating
Palmer p 60 marine engine
I have a palmer p60 engine in my sailboat, I had the starter rebuilt, replaced the ignitor coil but am still not getting a spark for ignition
  • 19 Answers
SOURCE: Car would not start or the engine wouldn?t even turn over.
Try removing spark plugs and turning engine over by hand with socket wrench on harmonic dampner if it spins freely probably not engine problem fluid in cylinders will cause hydro lock indicating blown head gasket or injector stuck wide open. a broken timing belt would still allow engine to turn over as your car should not have an interference engine. If engine will not turn by hand with spark plugs out susspect internal engine damage siezed bearings broken rod and so.
Posted on Oct 16, 2008
  • 1201 Answers
SOURCE: 1992 dodge 318 engine turns over, but no start. No
Some dodges have an oblong shaped white ceramic block, either mounted on the firewall or on inner fender well, with wire connections, one on each end, if there is one, replace it.
Posted on Mar 16, 2009
  • 38 Answers
SOURCE: GMC 2500 P/U 350 Vortec.. Installed rebuilt
Have you checked to see if your distributor is aligned properly? I just had to change out a distributor on a 1997 GMC 3/4 ton that has the V8 Vortec in it as well and you need to pay attention to the (2) numbers around the mating surface / rim of the distributor. You should see a number 8 and a number 6. You need to find TDC on your number 1 cyl. You can either slowly crank the motor over or turn the motor over with a ratchet and socket on the bolt securing the main pully to the crank while another person places their finger over the spark plug hole and when it just starts to Stop pushing air out past your finger then stop. Is the rotor aligned with the number what ever size engine you have in your truck (i.e. 6 or 8)? If not then your timing is off. You will need to remove the distributor and rotor, then install your rotor (before re-installing the distributor) and align the rotor pointer with either the number 8 or 6 stamped on the lip of the distributor where the cap sits down and creates the seal. I have found that they run both numbers on the distributor because they use the same distributor in both the V6 and V8 Vortec motors or a least the plastic base of the distributor. There will be (2) numbers here and sometimes hard to see. Align the pointer with what size engine you have and lower the distributor down into the hole. If the end of the shaft starts to turn the rotor as it aligns with the oil pump causing the pointer to no longer be pointed at the number that indicates which engine this is being installed in then you need to remove the distributor and look down into the hole where the distributor goes in and you'll see the end of the oil pump shaft with a slot (perfect for a big flat head screwdriver) staring back up at you. You'll need to insert a long shanked large flat head screwdriver down into the hole and turn the slotted oil pump shaft until you can successfully lower the distrubutor into place and not lose your mark. I also found that you'll need to have to pointer of the rotor a bit retarted from where it is suppose to be. This is because the distributor shaft gear is swirled and will cause the rotor to turn as it finds its mark, aligns and lowers down into a seated position. When it is seated and the rotor has stopped turning it should be pointing at the indicated cylinder Stamp in the lip that is your size motor (V6 or V8). Now it should be on time. The computer will take care of advancing and retarding.
If not the timing, then I would also consider that you may have a bad crank shaft sensor. These are merley suggestions because there is no more to go on than what you've submitted.
Posted on Mar 29, 2009
  • 3567 Answers
SOURCE: Honda CRF150F will not start
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Flush out the gas tank if needed.
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Post a comment to get back to me.
A “very helpful” rating on this answer? Thanks!
Posted on Jul 03, 2009
  • 77 Answers
SOURCE: Dayton Model 3E219 Heater - weak fire to ignitor
probably the coil.
Posted on Jan 22, 2010
Looking for info on replacing engine in cs36 sailboat with a Volvo saildrive is this possible?
you may get it from the net but I personally would find a marine volvo dealer or a good marine shop that handles volvo products and discuss what you want to do with them
the drive section will be or should be made to a standard fitting so that other motors can be fitted or there would be adapters made to fit other engines
face to face or on the phone is the best way to start resolving what you want as all the problems can be answered as you go
Jan 24, 2016 | Volvo Cars & Trucks
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
How to replace the coil
G13, engine?
its in the FSM and its free.
you unbolt it and put it back. its like very old school.
ah the pick up coil , the VR sensor and ignitor assembly
but that costs 2 times a rebult dizzy? why do that.>??????
there is a gap setting on the VR pickup.
http://www.fixkick.com/sammi-stuff/index.html
its in the chapter under spark ignition.
Cardone sells cheap rebuilt whole dizzy's
sold on rockauto.com
see em?
Jul 04, 2014 | 1990 Suzuki Samurai
Rebuilt chevy 454 engine, now need distributor and
just put a new starter in my 1993 chevy 454 and now i'm not getting fire, the old starter solenoid was sticking and melted the neg battery cable. I'm wondering if that also burned something else out?
Oct 27, 2009 | 1993 Chevrolet C/K 3500
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
West marine grill parts
magna makes most of the grills ive seen for boats am not familiar but it is possible they make it or something similar
Aug 22, 2009 | Grilling
1996 force outboard motor
Hello vickurzawski, You have a bad bendix. This is mounted on the starter to engage the starter to the flywheel. Check with a local marine shop or auto parts store for a new or used one. Disconnect the battery, remove the starter from the engine, replace the bendix on the starter. Connect a jumper cable to the starter to test operation before bolting back to engine. Make notes on what wires went where before disconnecting.
Aug 29, 2008 | Boating
86 tercel, 3ac engine, ignitor faulty, cannot find it??
it might be that the contact point within your distributor has worn out. you may have to just replace that.
Aug 12, 2008 | 1986 Toyota Tercel
Boating Logo
220 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
