Question about Briggs & Stratton Garden
My riding lawnmower will only stay on momentary. Gas is clean and spark plug is clean? The gas filter did have some water? What else can I check?
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Check the brass bolt (clean it thoroughly) that holds the float bowl on the carburetor. It is the Main Jet of the carburetor also and without a fuel filter and/or letting fuel evaporate in it causes the very small holes in it's bottom and sides to clog. Use no metal objects when cleaning/scraping. Wood or plastic only. You don't want to change the precise diameter of the fuel metering holes inside the jet. Clean it till it is shiny and reinstall.
Posted on Apr 05, 2011
Riding lawnmower turns over but will not start start
Could be several different things causing your problem. As a mechanic i've learned to never assume anyone has checked the obvious. So, since you didn't state what you may have checked:
1: Check to make sure you have gas in the gas tank
2: Check to make sure the spark plug wire is still pluged to the spark plug.
3: Check to make sure the fuel shut off valve on gas line going from tank to engine is in the fully open position. You may even want to remove the fuel line from the tank (putting a bucket below the valve to catch the leaking gas) and observe the flow. If it looks like it is coming out quickly, then I would guess that is not the problem.
4: Check the fuel filter in the same manner as above. Locate the fuel filter and remove the fuel line on the side of the fuel filter that is closer to the engine than gas tank. You should observe a similar fuel flow from the line as from the fuel shut off valve, if not, replace the fuel filter. They are cheap, so can't hurt to replace it if you are in doubt.
5: Check airfilter to be sure that it isn't clogged full causing the engine to draw in to much fuel and flood the engine.
6: Remove sparkplug (usually either a 3/4" socket or 13/16" socket and ratchet will remove it) and inspect the plug. If the spark plug has a lot of black soot between the electrodes then it is fouled out and needs to be cleaned, it could also be bad and need replacing. They are cheap and easy to replace, so in my humble opinion, when in doubt replace the spark plug. If the spark plug has a lot of fuel smell and it is wet, then the plug is either bad or choke is stuck in the closed position (or some call it the on position) or possibly the airfilter is clogged. If you checked the air filter earlier, and it is clean, then check the linkage for the choke to see if it is stuck in the closed or on position. To check it, remove the air filter and look down the large hold in the center and you should see a metal vane in an upright position for the choke to be in the open or off position. If the spark plug isn't fouled out or bad, or its new, and the plug isn't wet, then proceed to #7
7: Now that you have checked all of these simple things, you will need to give more information or take the mower to the local lawnmower shop and have it worked on by a reputable technician.
Sep 15, 2012 | Garden
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Riding lawnmower 42 in husqvarna i changed spark plug and gave it gas and charged the battery it acts if it wants to start but it just doesnt turn over
Have you checked the air filter? Look at the filter and hold up to sunlight if you can't see the light thru the filter then replace.
Sep 07, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Snapper lawnmower will not start - sparkplug is good, air filter clean, no idea what is wrong
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the vertical intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jul 05, 2010 | Omega Rear Drive Wheel Snapper Mowers
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
My craftsman riding lawnmower cranks over strong but will not start
Do you have spark? There are two things to look for when any engine won't start....fuel & spark, Take your plug out and lean it up against the metal of engine...turn it over and see if you see a good blueish spark.
No spark? Could be the plug, safety switch, coil
Next squirt a little gas into spark plug hole, replace the plug...will it fire up? If so...start working your way back down the fuel system....carburetor, fuel lines, fuel filter and gas (is gas old or new? is there any water in it?)
try that...www.nnyparts.com
May 29, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy built 6 75 hp lawnmower will not stay on I start it but it will quickly turnoff''
on the bottom of the carb. is a bolt that holds the float bowl on. remove that bolt and float bowl. use a small needle and stick it in the holes on the bolt to clean them out. look at the gas in the float bowl to make sure there is no water in the fuel tank .
Jul 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
65 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
