Question about HP Photosmart C6380 All-In-One InkJet Printer
I have an HP C4680..After a paperjam I am unable to print black and white. Copy comes out a very light green, almost unreadalbe...any suggenstions
    Guru:
  • 352 Answers
Sometimes the Paperjam can cause the print heads to mis-align. Pull out the cartridges, turn the printer off. wait 2 mins or so, turn the printer back on, replace the cartridges and try again. Also ink can build up on the print heads, causing print quality issues. See this link to clear it up. http://www.fixya.com/support/r3986425-unblock_print_heads
Regards GM
Posted on Apr 05, 2011
IR400 copier print to black copy
Not at all certain what your question refers to. The Hp Image Runner 400 is a black & white copier. What do you want to do that you are unable to do? Have you previously been able to do what you wanted with this copier, but can no longer do the same? What happens when you try to copy a document? Does the copy come out blank, or all black? Are you getting a large black area on a 8.5 x 11 inch sheet of copy paper when you attempt to copy something that is smaller in size, and therefore wasting lots of toner? Please explain your problem in detail, or no one will be able to help you. Thanks
Nov 24, 2014 | HP Office Equipment & Supplies
HP Photosmart C4680 prints only in Black and White
Make sure in the printer properties it is not set to print in b&w only.
Mar 25, 2011 | HP Office Equipment & Supplies
Printing stops because it thinks it's out of paper, even though there is paper in...
I had the same problem with the c4680, i fixed it for now but maybe the problems comes back.
What i did was removed the gray plastic cover on the back of the rpinter (turn printer around) and pulled 1 piece of paper a little bit futher then replaced the cover. Put the printer back on. The printer moves the paper now to the output side. remove the paper that came out. Push the power button off (i think printer most be totally off) and back on. Now try again to print of copy. Afther i've done that the printer works again. I hope this works for you.
Aug 15, 2010 | HP C4680 All-In-One Inkjet Printer
I have a new HP C4680 printer. When I print from
try printing a test page from the printer and if it works fine you need a software(HP smart web printing )
and you will get the software in the following website :
www.hp.com/go/smartwebprinting and there would be instructions given in the same page download and install the printer software and try printing from the internet using teh software and it shoul print perfect though it is complicated but this has been the best resolution for printing online
hope you liked the software and everything works fine
if you still have questions get back to us and we will surely help you
thanks
regards
Hamid
Feb 18, 2010 | HP C4680 All-In-One Inkjet Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Unable to scan or copy.
I also just found that I have the same problem. I called HP and of course it is out of warranty. I have only scanned a few things.
I have never had any luck with HP/Compaq. I think it's safe to say, "Don't buy HP Compaq". We also have a Compaq Laptop that it a POS, too.
Feb 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6380 All-In-One InkJet Printer Logo
161 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
