Question about Minka F8161BN Ceiling Fan
F 816-1-BN On rotation, forward or reverse, there is a cyclic noise that sounds like something is rubbing. It is not a knock and is not loud, but annoying. The fan is out of waranty, but has been used very little. Does FixYa sell a service manual for this model?
  • robertbertol Apr 06, 2011
    I am not at the place where the fan is located (condo). I like that you have given me several options and will try them on my next trip. I also contacted Minka and was able to get a manual on the fan. Thanks for the quick reply and suggestions.
  • 794 Answers
Hi robertbertol,
You may contact Minka directly so you can request for a service manual to be sent out to you through email. Their phone number is 1 (951) 735-9220 from 6:00 a.m. - 5:00 p.m. PT. They also have email address: sales@minkagroup.net.
You may also want to try some basic troubleshooting below that might help you address the issue about the noise from your ceiling fan:
If it's a mechanical sound, chances are it is a mechanical problem. It could be something as simple as a wire that has slipped into the path of some moving parts.
1. First, check if your fan wobbles. Balancing the fan may silence the noise. Theremight be some loose part hitting a metal housing piece.
2. Next, check the blades. Can you see anything coming into the path of the blades or any moving part. Remove the blades then, run the fan motor. If the nosie does not persist, something coming into contact with the blades.
3. You may also want to take a look on the motor.Open up the motor housing and rotate the motor slowly by hand. Observe where in it's path of rotation and at which point the noise occurs. Look also for any objects coming into contact with the rotor.
4. Observe also if the motor rotate smoothly. Dry bearings can also make a rubbing sound.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 06, 2011
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
Knocking noise when reversing
check your lug nuts. also check the axle shaft joints.
Jan 02, 2012 | Nissan N Z 38 POWER CAT Cars & Trucks
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 21, 2011 | Maytag Dryers
ELectric dryer on any setting makes a "Rubbing or squealing"sound when turned on and inside "drum" is rotating. Does heat up, just very loud/ Whats wrong?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Frigidaire Electric Dryer
Loud Rubbing noise from my Maytag Performa Dryer
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
Clunking noise from front when going forwards or backing up..jacked front end up..put car in N..spun both wheels and didn't hear any sound..where else can I check
usually the knocking is the drive bearings, or, the shock absorbers...so , i would check the shockers, if your wheels are rotating normally
Aug 06, 2009 | 1993 Ford Tempo
My dryer is making a loud banging noise on the left side of sounds like something is rubbing in it. Any idea what it might be, and how to fix it?
heatman101
76fg
Jun 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Loud Noise
This sounds like something is caught in the brush roller. It is not uncommon for something like a pin, or nail or something of that nature to get caught in the roller chamber and when the roller spins, it will rub on the roller producing that sound. Sort of like putting a playing card in the spokes of your bike when you were a kid. Take the bottom plate off and remove the roller. Inspect the area around the roller for any foreign objects. While your there, check the belt for wear and tension and also check the roller bearings for any material that would interfere with it's smooth rotation. You should also check the hose intake for blockage.
Feb 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Minka F8161BN Ceiling Fan Logo
81 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
