Question about Canon imageRUNNER 1310 Printer
Canon Imagerunner 1310 paper jam. Must be a small piece of paper jammed in the intake roller tht cannot be seen. How can I get the paper out?
  • 624 Answers
SOURCE: Hp Color LaserJet 3500 Paper Jam
The only way to find paper remnants is to unplug the printer and inspect the paper path. It also helps to have a good focusing flashlight, skinny needle nose pliers, a can of compressed air (used sparingly) and a long thin probe. Your specific printer should be giving you jam messages with a location code as well. I?ve attached a link to an HP page containing a diagram of the 3500 paper path and the error code jam locations: http://h41206.www4.hp.com/webapps/IV3/node.iv?locale=en_us&prodSeriesId=315862&node=prodITRC%2FNL_HW_IPG_plakCLJ3500_EN_01_E%2FN1%7C6%7C9&prodTypeId=18972&serverId=1#src I solved this problem in my shops years ago by not letting anyone else clear jams OR insisting that any paper removed as a result of a jam is given to me. If any corners or pieces are missing I know what to look for and approximately where. Good hunting and please don?t forget to rate this post.
Posted on Mar 21, 2007
  • 29 Answers
SOURCE: Minolta 2350DL laser printer paper jam that will not clear
You have to take off the roller . :)
Posted on Jun 19, 2008
frankzjm
  • 191 Answers
SOURCE: paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Posted on Dec 22, 2008
  • 990 Answers
SOURCE: canon imageRunner 3200n paper jam in the fixing unit
Hello sir;pull out fixing unit check out the paper sensor that located at the paper exit side,let it move freely.
Posted on Jan 10, 2009
  • 214 Answers
SOURCE: paper jam in hp photosmart c4280
What have you got to loose, get in there and try!
Posted on Apr 24, 2009
It says paper has jammed after photocopying 3 or more papers
You may have a small piece of paper stuck in the wheel area that you may not see. Dust can cause this too, like ink.
Nov 11, 2014 | Canon imageRUNNER 3025N Cassette / Bypass...
Jam 0205 in ir5000 canon machine. Please give me
there could be a small piece of paper stuck wehre the vertical path sensor is. it is showing a stationary jam at the vertical path 3 paper sensor. there is more than likely a sensor that has become wedged or has a piece of paper holding the sensor closed instead of open in or around drawer #3
Jun 11, 2010 | Canon imageRUNNER 5000 Copier
Canon imagerunner 11025iF. Cleared a paper jam,
there is a possibilty that one of the jam sensors is stuck and needs freed and or a piece of paper is blocking the sensor.
Jun 02, 2010 | Canon Office Equipment & Supplies
I have a problem with an error of "Jammed paper" and I cant see any paper jammed, What should I do?
Sometimes a "jammed paper" error message is caused by a very small piece of paper lodged inside around a roller, and can't be seen with removing a cover or something, It isn't always a full sheet of paper in an obvious place that causes the problem. poke around inside and look for a tiny culprit, goodluck!
Mar 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper keeps jamming. Now it has a small piece of paper stuck in machine. Any help besides serviceing?
Sir, were does the paper jam? we need to remove that paper. and try to clean the feed rollers with wet cloth with water or alcohol then try it.
Feb 24, 2010 | Canon imageRUNNER 210S Copier
Paper jam at output on the Imagerunner 1310
I have a solution. Take a baseball bat and knock the crud out of that ******! That will fix the problem of not having a door! Thus it will make a verrrrrry easy opening to get the paper out! :-D
Feb 04, 2009 | Canon imageRUNNER 1310 Printer
Canon imageRunner 3200n paper jam in the fixing unit
Jan 10, 2009 | Canon imageRUNNER C3200 Copier
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Paper jam
Paper jam
You need to take out your paper tray and ink cartridges and make sure the power is off. You should also be able to remove the lid so that you can clearly see the paper path. Do not **** on the paper with a great deal of force because you may dislodge something more than just the paper. You may have to remove any covers that obstruct your view of the paper path. Just be careful and take your time and remove it a little at a time if necessary. With the power off the rollers that it goes over should move freely and you can turn it by hand to feed the pieces of paper manually through.
Dec 11, 2008 | Canon imageRUNNER 1310 Printer
Canon imageRUNNER 1310 Printer Logo
165 people viewed this question
old marine
old marine
