Got a new government CAC card on Firiday, now my home card reader doesn't recognize it. Getting unrecognized profile error. New card works fine at work.
SOURCE: Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Posted on Sep 27, 2007
  • 263 Answers
SOURCE: Cisnet card reader
yeah you need drivers for the sd card http://www.driverguide.com
Posted on Jan 05, 2008
SOURCE: HP 9250c Digital Sender
The CC543A is the approved CAC reader from HP. That is what we are using on these devices throughout our organization. The reason some CAC readers do not work is because the STIGS on the device from HP require that the device software for the readers also be used. The readers are about $300 each.
Posted on Jul 20, 2009
bob_computer
  • 3153 Answers
SOURCE: systemprofiler does not recognize glyph Unknown
1394 is fire-wire. Some cheaper fire-wire chip-set cards can have minor issues.
Usually they are sorted by removing it and placing it in another slot on the motherboard. If it continues to cause issues then consider a better card..
One of my servers had this issue until i changed to a better card.
If you are using BLUE-TOOTH then watch how far away from the source you are as blue-tooth only has a very limited transmission range and is susceptible to cell phones, wireless phones, baby alarms, and other radio interference.
Posted on Oct 09, 2009
SOURCE: i have toshiba portege r600 and need to get cac card reader
It really doesn;t matter which one you choose as long as it works. One is no more "Secure" than the other.
PCMCIA cards are great, So are Express cards. But as said whatever works. Just make sure it has relevent current approved drivers etc. ya be good to go.
Posted on Jan 18, 2010
I have a government gateway ID and a password but every time I try to use it Iam told it isn,t available to me can you tell me why?
If the Gateway is not linked to the government network through your department or agency's router and/or hub system, your gov't ID won't do a thing in the CAC reader. If your security clearance is no longer current, your CAC won't allow you to get into the network either. If there are other issues, please contact your department or agency's Network Administrator or IT specialist to grant you access. The ID card that has a chip of it may be corrupted and you may need a new one too!
Mar 09, 2015 | Gateway Computers & Internet
Dfas my pay login
You should be logging in from a government PC with your CAC. If you are not you can request the proper certificates and buy your own CAC reader to use at home. Talk to your IT department. There is no sense in trying to keep memorizing that insane password. If you are not the user you're claiming to be remember the minimum fine is $5000 and jail time.
Jan 07, 2014 | Computers & Internet
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
Pc doesn't recognize digital camera
I'd say the easiest and best solution would be to buy a card reader. Not only would a reader get your irreplaceable photos onto your computer, it will work with your next camera and computer if and when you ever replaced either.
Feb 19, 2012 | Cameras
Hi, have a delllatiude D520 with dockinstation, everything worked fine sudently the power gets to the DS but an error message appears and says that it doesn't recognize power source, push F1 to exit,...
Check the dock connectors and clean them with a dry cloth if possible. The error message usually occurs when an unrecognized, or third party charger is used. This can also occur when the charger is loosely connected. If the problem continues even if your docking station is dell-recognized, and you have cleaned your connectors, then you need to contact dell support for further assistance. Alternatively you may ignore the message if your laptop continues to function normally (i.e. normal battery charge/discharge times and no excess heat production).
Jul 03, 2011 | Computers & Internet
I have an IOGear GCS1734 KVM switch and two Windows based machines. I work for the gov't and we have to use a CAC Card. My keyboard has a slot/reader for my CAC card to verify my credentials. If I...
As far as mouse is concerned all you need is PRACTICE, and there may be a compatibility issue with your keyboard or the wire you are using is not fine, coz the kvm switch is definitely ok when used with 2 systems.
Oct 19, 2010 | IOGear USB gcs1734 4-port KVM Switch
Cac is readable by reader but is not permitting its use
ActiveCard Gold had known problems that were never fixed. Upgrade to the newer Active client 6.2 very reliable and stable CAC program. Also has several very useful tools in it as well. DoD switched to this a few years ago and has worked very well.
May 21, 2010 | ActivCard Gold 2.2 for CAC (gacg22cl)
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Apr 13, 2009 | HP Digital Sender 9250c scanner Printer
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
