Question about Sport & Outdoor - Others
I have a fishing buddy 1200 and every time I turn it on, unit 9 failure check battery shows up on the screen. What is unit 9 failure and how can I repair the problem. I have tested the batterys and they have tested good. Can you help me?
freetek
  • 5568 Answers
SOURCE: Unit is switching to battery power for now reason.
Any UPS monitors the incoming AC level to determine if it is needed or not.  I think the APC unit doesn't know any more when it is needed; it's sick.
Posted on Sep 23, 2008
  • 50 Answers
SOURCE: 99 discovery/ dies while driving
sounds like the belt is loose. if it has a tensioner check and or replace it, if not tighten the belt. or the alternator tests ok but is actually not working at low rpm. or the battery is shorted. electricity is tricky
Posted on Dec 07, 2008
  • 2920 Answers
SOURCE: check engine light on, code p1633 pops up, battery good what now!
check the alternator you should be getting more volts than that..
Posted on Jan 21, 2009
SOURCE: Error Message: PXE-E61 Media Test Failure Check Cable
the problem on my laptop is when it starts up it says media test failure chech cable so what would be the solution for this.
Posted on Feb 21, 2009
GM Elec
  • 1000 Answers
SOURCE: Battery and Alternator Good. Alternator not working. HELP!!!
djn, I believe you have some accessory that is on when the key is in the off position.
Check to make certain glove box light is not on when the glove box door is closed and the trunk light is not on.
If you have an aftermarket radio or any added accessories make sure they are not wired direct to battery voltage.
If all that checks out, disconnect the battery negative and connect a test light between the battery and battery cable. If the light is on you have a drain in the electrical system. Leave the light connected and begin removing 1 fuse at a time until the light goes out, that will tell you what component or circuit is draining the battery.
Last resort, you may have an alternator drawing the battery down.
Good luck and let me know.
Regards,
Posted on Mar 01, 2009
How do i get the fish on the screen to look like fish
Your unit should have a setting labeled "FISH ID" turn this setting on and you will see fish shaped icons instead of arches on your screen. You may also see numbers by these icons. Those numbers represent the depth of the fish at that moment.
Be forewarned that at times your unit will show the fish icons when there aren't actually any fish below the boat. Hope this helps.
Sep 16, 2014 | Boating
Lowrance fish no display
its history buddy screens out time for a new one
Apr 18, 2013 | Lowrance Boating
HDs 8--detecting bait fish?
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Feb 06, 2013 | Lowrance HDS-8
Need parts for fishing buddy 1200
I need the handle for the fishing buddy. This type is the one that allows 3 'C' batteries to go inside. Willing to pay any price within reason. Email me at grtrapper936@gmail.com
May 28, 2012 | Bottom Line GPS
When I turn on my humminbird ice45 flasher a thin green line appears on the flasher then goes away. The only thing on is a dim light in the background & small digital screen where depth is shown. When...
If you know someone who has the same type unit, you could try your unit screen (control head) on their hookup to see if you obtain the same results. If so, there could be a problem with the unit and it would need to be shipped back to our factory for a service test. If you do know know anyone with the similar unit, please contact me at the following email address and I will send you a transducer to test with the unit. sbates@johnsonoutdoors.com
Sharon, Humminbird Consumer Service
8-5pm - Central Time - Mon-Fri.
1-334-687-6613 ext. 1202
Dec 21, 2010 | Humminbird Ice45 Ice Fishing Flasher ()
I have the ink system failure error and error Oxct18a0206 I was going to try and fix it and it somewhere it said that it could be because the ink cartridges are low. How do you see what level they are at...
Yes, The error is caused by air in the ink feed tubes which happens when the ink in the cartridges runs out or you use an improperly filled cartridge. We have a step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
There is not any easy way to determine the level of ink in the cartridges but you will need to use full cartridges when you do the air purge procedure needed to clear the error.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Screen shows images on fish instead of arches
Most sonars have a setting for FISH ID, on or off.. Not sure on the type of unit you have, so hope that helps. I've seen where hummingbird fishing buddy only have fish images and not arches...
Mar 02, 2010 | Boating
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Sport & Outdoor - Others Logo
83 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
