Question about Samsung PCJ534RF 53" Rear Projection Television
My remote wont fix a problem it should
When the red and blue fall out of alighment i went into the menu and found a function that should let me fix it with the remote but the remote does nothing at all. is their a way to reprogram my remote or something else i can do.
    Genius:
  • 1,139 Answers
I posted this recently, but it applies here also:
This sounds like a convergence problem which means that yourconvergence amps have malfunctioned. You can change these out yourself,however you will also have to change out all of the biasing resistorsconnected to the amplifiers. To do this:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK329-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK329s are 110, 120 or 150.
4)if the STK329-xxx's are 110s replace with 110s (forget that upgradestuff it is a hit or miss game that I don't believe you want to getinto), if they are 120s replace with 120s and so on.
5) Now toreplace the STKs: remove the module from the TV and unsolder the oldSTKs along with the bias resistors, and replace them with the new ones(be sure to apply heat sink paste to the STKs when attaching them tothe heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do an auto-convergence test and then things should be back to normal.
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Thank you,
I hope this helps,
Shuttle83
Posted on Nov 01, 2008
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Tv wont turn on. toshiba 37c3030d
The internal power supply has died. take it to a repair facility.
Aug 13, 2009 | Toshiba 37C3030D 37 in. LCD Television
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
We bought an additional wii remote and have tried to sync it but all we get is all 4 blue lights flashing??? wont work? thanks
Well, I don't have a Wii myself but I did some checking and found this. Hope it helps.
When you first get a second Wii remote, you have to press the red button inside the battery compartment and you press the red button by the Wii's SD Card slot simultaneously. Then you turn on the game and you press the Wii menu button. Go to controller settings and select reconnect remotes (can't remember if that's the exact words, but it's something like that). Next you hold 1 and 2 on the first remote, then hold 1 and 2 on the second remote. And that should do it.
Jan 19, 2009 | Nintendo Wii Remote Controller
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Blues
Ok Dragonlady On the remote theres a button that says function or will have an F on it. At the same time press the F or Function button and the Mute at the same time. Now remember once its unlocked you may need to reprogram by going into the menu. If you have any more problems call Apex at 866-427-3946, they are very good with helping their customers. Hope this helps. Good Luck
Jun 09, 2006 | Apex Digital AT2708 27" TV
Samsung PCJ534RF 53" Rear Projection Television Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
