Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
What is the jumper setting for the drive to me a master with a slave?
    President:
  • 1,851 Answers
You can view the jumper settings at this picture:
In case you'd like a better quality image you can go at this link and scroll down to the page 26.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 05, 2011
    Genius:
  • Samsung Master
  • 1,479 Answers
These should take you to the relevant info
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=SP1604N&srchword=SP1604N
http://skp.samsungcsportal.com/integrated/popup/FaqDetailPopup.jsp?cdsite=au&seq=20807
4 Suggested Answers
SOURCE: jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Posted on Jan 08, 2009
Hannibalwr
  • 99 Answers
SOURCE: jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Posted on Sep 05, 2010
  • 2246 Answers
SOURCE: master/slave settings on sp411c samsung drive
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Posted on Feb 09, 2011
Testimonial: "I thought of that the second day but was not sure if that was all as there are 4 sets of pins on the drive. I get to test it tonight."
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
Select as master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
slave :::':
Oct 03, 2011 | Dell Computers & Internet
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
886 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
