The picture is fine when watching standard cable through HDMI and dvd through AV1 or AV2. However, the picture when using component 1 or 2 for x-box or wii the picture has no color.
  • 3 more comments
  • paulreser Apr 05, 2011
    Vizio model number VX32L
    Yes, b&w and grainy
    Yes, b&w and grainy.
    I'm sorry. Don't know if my response has gone through. Yes the picture is B&W. The wii and xbox both work fine when connected to the AV 1 and 2 inputs.
    yes
  • 10,594 Answers
Let me know model number and brand of your tv to look for possible cause of problem.
Thanks.
Posted on Apr 05, 2011
  • Shahid Electronics
    Shahid Electronics Apr 05, 2011
    Thanks for model and brand info.
    Do you get black and white picture in component-1 and 2 input?
    It seems video processor chip that gets component video input signal got bad and causing problem. This chip is mounted on main board that need to be replaced.
    Shopjimmy.com is good source of main board for Vizio VX32L, currently it is out of stock, please call shopjimmy.com as numbers are written on bottom of page and inquire about availability.
    Thanks.
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
thanks
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
How do I stop my channel changing.
hi i'd put your sky box to av1 and dvd player to either av2 or hdmi 1 hope it helps
regards
shaun
May 04, 2014 | Hitachi 32LD8700 32 in. LCD Television
I need remote codes to program my directv control to my bd p-1500 blu ray dvd
hi,
Try any one of the following code.
20490, 20573, 20820, 21075, 20899
Progarmminig procedure
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
Feb 21, 2011 | Samsung BD-P1200 Blu-Ray Disc Player
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Jul 21, 2009 | Toshiba XD-E500 DVD Player
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Televison & Video Logo
Top Televison & Video Experts
