Question about Sharp LC 37D62U 37 in. LCD HDTV
Maximum volume on the set is too low!
I cannot hear the television from across the room. Not sure if its defective or if its because of the cable box that I have hooked up to it! help!!
Thanks for the help!
Amy
  • inneedofsoun Dec 08, 2008
    the volume (even when set on max) on our brand new 37 inch sharp is too low.
  • 41 Answers
On some cable boxes they have their own volume control. Raise the volume on the box if you can. if the volume on the tv is up all the way it should be loud. It should not be the tv if you have volume already coming out. try hooking up a dvd player or some other device and see if you have the same result
Posted on Aug 08, 2008
6ya staff
SOURCE:
No volume sound very low at maximum
Look both at the set and the Box if used (cable or sat) to make sure volume is not turned down---also a receiver if used can do the same thing.
A quick low tech test is do you have the same problem when playing a DVD etc.
Apr 24, 2012 | LG 42LC2D 42 in. LCD HDTV
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
Low volume even when on 100 on a brand new vizio
Try running the cable straight from the wall into the set and see if it's ok. If not, then I would exchange the set.
Oct 10, 2009 | V, Inc. VIZIO RP56 Rear Projection...
Very low sound
If you are using a cable box, the problem may be in the audio settings menu of the box. Check to make sure that the audio levels are set to maximum and save the changes.
Often these get changed accidentally.
www.mcveyelectronics.com
May 03, 2009 | Televison & Video
Sharp 32c231 volume too low
If you are using a cable box with this set, the problem may be in the box settings.
Try this:
open the settings menu on the box . You may have to select"more settings" or something like that title to find the audio selections.
Under the audio, you will find recording and viewing volume settings. put these to maximum and save.
Your volume should now be more than adequate.
May 03, 2009 | Sharp 32C-240 32" TV
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Toshiba 19LV505 combo/dvd tv that has absolutly the worst sound, the setting only goes up to 50 and you still have a hard time hearing the tv. Is it just poor speaker quality. I have cable hookup and hdmi...
Bob, you need to first raise the volume on the actual cable box itself. On each cable box there is a channel (up and down) as well as volume (up and down). Set the cable box volume to maximum, you can only do this manually at the cable box. This should work.
Dec 16, 2008 | Televison & Video
Low volume when volume control turned all the way up
I just had the same problem. Unplug the both the TV and the cable box for 5 minutes.
Dec 03, 2008 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Sharp LC 37D62U 37 in. LCD HDTV Logo
334 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
