Question about Acer Aspire 5742Z-4200 Notebook
A "disk read error
    Scholar:
  • 93 Answers
Try locating the hard drive - its usually under a cover that can be unscrewed check that the drive has not become dislodged try unplugging it then plugging it back in .
Posted on Apr 07, 2011
ginko
  • 19396 Answers
SOURCE: computer reads:A disk read error occurred
First ensure that you have no CD inside, and that no USB memory stick is plugged.
case one : you get "a:\No system disk or disk error" prompting that there is no floppy. Even if there is no floppy on the machine. That is because BIOS has a virtual A: drive.
Go to bios settings and change bootup sequence put C:\ first
Case two, the system cannot boot and you have generic "No system disk or disk error" because it cannot load the system from C:\ drive.
In this case try reinstalling the system using windows install disk or a recovery disk. If it does not work, the disk may be damaged, and you will need to have it replaced or formatted.
Posted on Dec 20, 2008
crayzeetrayn
  • 837 Answers
SOURCE: a disk read error occurred
More than likely you have a hard drive failing/failure.
You should have it looked at if you are not "comfortable" doing it yourself.
Posted on Jan 07, 2009
acdr
  • 1913 Answers
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
jexty
  • 5 Answers
SOURCE: a disk read error occurred, press ctrl-alt-+delete to restart
Restart your machine and while rebooting, press F8 button and boot your system on safe mode. After booting in safe mode, try to reboot it again.
  • 1752 Answers
SOURCE: how to fix a disk read error occured?
Sorry, it's time for a new hard drive.
Posted on Nov 19, 2009
Ok so i have an acer laptop and when i start it up it comes up with "A disk read error occured press CTRL+ALT+DEL to restart" when i do that all it does is restarts and goes back to the...
There might be a problem in your Hard drive. If you have tried so, Try removing your hard drive and set it up again. If it still doesn't work.You may try using a recovery disk or the cd used to install the operating system. If still the error is appearing, try to reinstall the operating system. if still, I'm sorry you might need to replace your hard drive.
Aug 28, 2011 | Computers & Internet
I have an HP Xp laptop that is not loasing any programs when I turn it on. The screen says, " a disk error occured, Use cont, alt, del, to restart. After I do this the same message comes on. What is...
The computer cannot read your copy of Windows from your disk-drive.
So, you get the "disk-error" message.
Take your computer to a qualified technician for professional trouble-shooting.
Aug 04, 2011 | HP Computers & Internet
When switch on,the massage "a
This seems to be a failure of the HARD DISC and so the PC does not boot and go to the OS.
This means that the hard disc must be replaced if the PC does not boot up and so the OS must be reinstalled.
Aug 02, 2011 | Computers & Internet
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
I'm getting a screen that says "A disk read error
this problem caused by error connection at hard disk, your hard disk can not read by your computer
to fix this problem you need to open your laptop then disconnect your hard disk from laptop, and connect again
and turn on your laptop
the problem like this usually found at computer with sata hard disk connection
i hope this helpful
Apr 04, 2011 | Acer Computers & Internet
"A disk read error occurred. Please click ctr +
You have as it states, a disc read error which means you have errors on the hard drive.
As soon as you get into your system run CHKDSK/F, that will attempt to restore the damaged files.
Make backups and look for a replacement hard drive.
Hope that helps.
Feb 16, 2011 | Acer Aspire One PC Notebook
You have problem at the boot sector of the disk. Maybe it's hardware problem (controler, disk) or maybe it's a virus. Shut down the system and try start it up after some minutes. If it start up make a full back up just in case ......
Stelios.
Feb 21, 2010 | Computers & Internet
How to fix a disk read error occured?
Nov 19, 2009 | ASUS Eee PC 900 16G Notebook
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
Acer Aspire 5742Z-4200 Notebook Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
