Question about Magic Chef Dryers
How do you install a thermal fuse kit on a Magic Chef CYE4000AYW. Unlike other models it doesn't look like you can just take the back panel off; do you really have to take the top and back off?
    President:
  • 1,554 Answers
The thermal fuse kit is accessible from the top of the dryer. Disconnect power and using a putty knife, release the two spring clips holding the top cover to the cabinet. Insert the putty knife in the seam between the top cover and the cabinet at about 4 inches from the sides. Lift the top cover when the first spring clip is released while releasing the second clip then lift the top cover to the rear of the dryer.
The high-limit thermostat is located on top of the heater housing at the rear of the dyer. Remove the screw that secures the high-limit thermostat bracket anHow do you install a thermal fuse kit on a Magic - jahn27_263.jpgthermostat.
The thermal fuse is located on the right hand side of the heater housing and is mounted on a bracket. There's a 1/4" hex-head screw that holds both the heating element and thermal fusHow do you install a thermal fuse kit on a Magic - jahn27_264.jpgmove the screw and the thermal fuse bHow do you install a thermal fuse kit on a Magic - jahn27_265.jpglifted off.
The thermal fuse bracket has two locating tabs, one at the bottom and the other is half-way up. Lift the bracket to clear the tabs then remove it and replace the thermal fuse. Reinstall the thermal fuse and high-limit thermostat brackets in reverse order of the removal steps. Press down on the top cover against the cabinet to reengage the spring clips.
Posted on Apr 06, 2011
How do I open the back of the dryer to get to the heating coil? My dryer isn't drying clothes.
Magic Chef Laundry Parts Model CYE3005AYW
This link has a better schematic. Note the thermal fuse. Check it first.
If it is open you need to determine why it opened. Is the exhaust pipe clogged or does it have to many elbows or is it too long.
4 elbows is about equal to a clogged pipe.
Is there something wrong with the thermostat that caused it to overheat?
My CYE3005AYW Model Overview from PartSelect com
A youtube video shows where the heater is.
Magic Chef electric dryer
Sep 29, 2014 | Magic Chef CYE3005AYW Electric Dryer
No power to my Magic Chef over the stove microwave oven. Is there a fuse that can be replaced, and where if so?
There should be a fuse and one or more thermostats or thermal cutouts.
We would need your full model number.
Nov 30, 2011 | Magic Chef Microwave Ovens
Where can i find the thermal fuses on a magic chef by maytag model CYE3004AYW?
What you need to do is unplug the machine then use a flat blade to pop the top the heater and high limits along with the thermal limit is in the rear.
Mar 20, 2010 | Magic Chef Dryers
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Dryer stopped working - cye4000AYW
The answer is likely yes. Look on the back of the dryer, for an open hole that seems to serve no purpose. using a flashlight, peer inside this hole, and any others like it, and look for some sort of button.
Also make sure power is disconnected before doing any of this.
Dec 16, 2009 | Magic Chef Dryers
MAGIC CHEF DRYER CYE2000AYW
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
plumber, pop the top on the dryer by pushing on the two clips just under the top on each side. In the back you will see the heater. You want to check the high limit thermostat (this one sits on the top side of the heater) and the thermal fuse (sits on the side about 4 inches down. Unplug the dryer and check them with a meter. If either shows open (no continuity) replace them. Make sure your venting is not clogged up and the heater is not grounded or fractured. Part number for the high limit is 53-0771 and for the thermal fuse is LA-1053. Check these first...Catriver...post back. Unable to find your exact model, but I do have cye4000ayw. parts should be the same.
Oct 12, 2006 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
588 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
