Question about Keurig B60 Coffee Maker
What is in the Keurig that keeps attracting ants to get inside of it?
Tip
Baby carriers and cribs
tips:check the carrier to hold and can support the baby. check the lock to ensure the safety of the baby, and for the cribs, clean first before you put the baby inside because sometimes there are presence of small ants attracting the milk that spill inside.
on Jul 19, 2010 | Baby Gear
Fire ants in conduit
fire ants are attracted to the eleectrical components of contactor & swiches. use some ant powder on areas around conduit.
Sep 15, 2013 | Bryant Heating & Cooling
Is using termite control around my garden dangerous for my family?
Any use of chemicals poses some level ofrisk, but with the right precautions it doesn't have to be dangerous to yourfamily. Read this article to get more information about Termite/carp/ antkiller products and their risks.
http://www.termitecontrol.net/dangers-of-termite-control.html
Jul 17, 2012 | Bonide Termite/Carp. Ant Killer Conc. 1...
I put milk in my Keurig and now it won't work...i think the milk burned
..wait..you mean you poured actual milk into the water reservoir on a Keurig coffeemaker..?
That's not good.
What prompted you to do that?
My advise would be to boil water in a kettle, adding about a half-cup of regular vinegar. Pour this into the coffeemaker and let it run through a cycle with just the hot water/vinegar solution. Next, run plain hot water through it.
Hopefully, this will help with flushing out any/all milk that's clogging the coffeemaker. You may have to do this several times to remove the milk residue..milk will cling. (and will start to smell foul..which may or may/not attract insects) so don't ever do that again!
Phoning Keurig Customer and product support may assist you further. They are generally very helpful with all inquiries and issues.
Keurig single-cup coffeemaker
http://www.keurig.com
(866) 901-BREW (2739)
Jul 12, 2012 | Keurig B30 Mini Coffee Maker
How do i get ants out of my coffee machine
First spray you house for bugs as this is not a good thing. Wipe unit with paper towel on the bottom section saturated with bug solution. Wait a Day and they will die. Wash surface and go.
May 02, 2012 | Keurig B60 Coffee Maker
Ants in my Keurig
I had the same problem after getting a Keurig model 525C and took it back to Costco, with ants still in the coffee maker. I haven't had this problem with other Keurig coffee makers. Keurig needs to come clean and admit THEY have a problem with at least one of their coffee makers.
Apr 25, 2012 | Keurig Ultra B50 1-Cup Coffee Maker
Well my Keurig wasn't working as fast as it used to and this morning when I went to add water...I removed the cover and a zillion sugar ants came pouring out of it. Right from the hole where the water...
I HAVE THIS SAME PROBLEM WITH ANTS IN MY KEURIG. I've had ants in the past during the springtime and I've never had a problem with any other coffeemaker being infested with ants. I saw two ants actually crawling around underneath the blue brewing light while the machine was brewing plain water! I've de-scaled it with vinegar and have run water through it over and over and over again. There are STILL ants in it. It's currently outside my home and I have no other ants in the house. I called Keurig just to see if they have heard of this happening and they told me no and that it's an environmental problem. That's obviously a lie because all you have to do is Google Keurig and ants and you can read of other problems. I think I am probably going to throw the Keurig away . . .
Feb 19, 2011 | Keurig B60 Coffee Maker
Digital camera
I am guessing the only solution would be to take the camera apart to get the ants out.  So, you would be best to take it to a repair shop and see what they think.
Sep 21, 2008 | Canon EOS 40D Digital Camera
Keurig B60 Coffee Maker Logo
117 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
