Question about HP PSC 1210 All-In-One InkJet Printer
When I turn on the printer I hear the wheels spinning but the paper does not go in and the ERROR light comes on. Everything stops except the blinking yellow light. I installed new cartridges.
  • kemosabe9 Apr 09, 2011
    THANK YOU FOR THE HELP. I CAN'T FIND ANYTHING IN THE WAY.
    WITH THE PRICE OF PRINTERS SO LOW I'M JUST GOING TO BUY A NEW ONE.
    THANK YOU JUST THE SAME.
    President:
  • 739 Answers
Hi
Normally the problems you face are due to sign a paper tray stuck. go check the paper tray, make sure that no matter which prevents the paper. if there is a little to disrupt the process roller to work and the printer will give an error and stops operating.
easy way for you to overcome these problems is to do a test print using the hardware, such as glossy paper, do the cleaning roller through the printer properties. if it still fails to produce material that prevents the roller, you need to open the printer's cassing to remove it.
regards
Posted on Apr 06, 2011
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- press and hold your finger at on/off with reset/stop button together
- turn on printer power switch
- release the button on / off, but at the same time continue to press the stop / reset and then press the button on / off again and continued to hold the two buttons.
- wait a moment
- relese stop/reset button 2X.( you will see the led light blinks twice when you press the stop / reset twice)
- release on/off button.
wait until the screen on the printer control panal shows the number 0.
- after printer panel screen shows number 0.
- press stop/reset button 4x
- press on/off button 1x
- wait until you hear the movement of your printer roller
- when you hear the movement of the roller your printer, wait a while until you do not hear any sound of movement in your printer. :)
- turn off and turn on printer again and your will see your printer back to normal.
Ok world...Good luck
------>>>Download guide to fix waste ink overflow ip1000 Click Here
on Jul 21, 2010 | Computers & Internet
Both lights are blinking, but paper is not drawn
Check to see if feed rollers are turning but not picking up the paper, if they are turning try clean with windex and see if dirt comes on the paper, if so either clean wheels reall good or the wheels need replacement.
Jul 23, 2014 | Epson Office Equipment & Supplies
I have an Error 2 that happens when trying to scan a document. It makes a clunking noise. How do I fix this? Thanks in advance!
E2 error means is a paper jam.
Solution 1
Turn the printer off, then on again. Sometimes, when Pinter turned on, the position of the wheel is not correct, causing the error E2. By turning off the printer and then turn back, the position of the wheel will return to normal. This way I've ever done and it worked.
Solution 2
You turn the sensor vertically, as opposed to clockwise. By rotating the sensor vertically, roller wheel position to be shifted, so it will return to normal position. Rotate the sensor vertically, until you hear the sound (clak) of the wheel roller.
Nov 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
For Canon mp210. Error light blinks. Either E22 or E2
Hi there
This is a Carriage error take a good look at the carriage that the inks are in and see if they are sitting ok and also do the next incise there some thing there stopping it from moving.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 07, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Slow blinking error flashing
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Jul 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
'paper send error'
Did you buy this printer new & how old is it, I think you should contact the people you got it from
Jun 15, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
LaserJet 1200 Stops pulling paper
If the printer works fine for you, but doesn't work properly for someone else I would assume user error. Just make sure that there is plenty of paper in the tray and that it is centered. Also look around for any small peices of paper that might've gotten stuck near the tray, preventing new sheets from getting pulled.
May 06, 2009 | HP LaserJet 1200 Printer
Tv work come on , all 3 lights blinking
All 3 leds blinking is a Lamp error. Pull the lamp and see if it is blown. If so, replace. This error can also be caused by many parts of the optical block = colorwheel, balast, or DMD board. If you hear a buzz sound when it tries to fire lamp then the lamp is bad. If not listen for the spinning high pitched squeel of the colorwheel coming up. If you hear this but no buzz from the ballast, you likely have a bad ballast. If you do not hear the color wheel, you have a bad color wheel or DMD board.
Dec 07, 2008 | Akai Televison & Video
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
