OS: Windows Vista SP2 Printer: Kodak ESP 7 Connected: Ethernet Network Fault: Will not scan Error Code: 100-2106
  • 1 more comment
  • des_venz Apr 09, 2011
    The file aioscannr.msi does not exist on the CD or the HDD. Unable to find it even with advanced search.
  • des_venz Apr 10, 2011
    Have tried to install on another computer also with you solution but a dialog box appears for 1 second stating that it's preparing to install then disappears with no results. It appears the software on the CD may be faulty. Is there anywhere to download this file (aioscannr.msi )?
    Have tried uninstall and reinstall to no avail. There are no up dates to my software and the processor supports SSE. Is it possible it's a hardware problem? It will copy documents when using the printer panel; that is why I thought it must be able to scan to the computer also.
    Cheers,
    Des.
  • 2,574 Answers
  1. Lift the scanner lid, and place a document face down on the glass.
  2. Close the scanner lid, then press Menu (or Home).
  3. Select Copy Document, then press Start.
    IMPORTANT: You will need the KODAK All-in-One Printer Software CD, that comes with your printers, to do the following steps.
  4. From your computer desktop, click Start > Run.
  5. Type %windir%, then click OK.
  6. Double-click twain_32.
  7. Right-click Kodak, then select Delete.
  8. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
    NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
  9. Double-click aioscannr.msi, then follow the instructions to remove it.
  10. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  11. Open Home Center Software:
    1. Select Scan Documents and Pictures.
    2. Scan a document.
Posted on Apr 06, 2011
  • Reparatii PC - Service IT
    Go to www.kodak.com/go/2005 to run the SSEUtility.exe.
    Do one of the following depending on your browser:
    WINDOWS Internet Explorer: Click Run, then click Fix.
    MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
    Install the KODAK All-in-One Printer Software.If the message "your processor supports SSE and the utility will not be able to help" appears, click the X in the upper-right corner to close window.
    Please click here to download aio installer.
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 7 doesnt scan or print properly HELP
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. KEEP ME POSTED.
Jun 11, 2009 | Kodak ESP 5 Printer
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
571 people viewed this question
k24674
jasbo
jasbo
